Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-24-2009, 09:11 AM   #1
PocketRocket's Avatar
Default ESC overheating...help plz!
hi, on the back of my reedy challenger 19t motor, it says
"Correct gearing is critical. An incorrect gear ratio my result in excessive motor and ESC temperatures..."
It also came with a little table that said that a 1/10 touring on rubbers need a 6.4:1 FDR i havent a clue what that means
So i raced regardless and now... my ESC is getting too hot and cutting out.
I thought it was because the ESC is to weak for the new motor, because its very good, keeps up with my mate with brushless!
I found out that my ESC has a rated current of 75A...but i don't know the motor.
So, any help i will be thankful for. my ESC is a LRP AI Runner Plus reverse no.83060. Motor is a Reedy CHallenger 19t spec racing motor, my car is a Schummacher mi2
Thanks!
Greg
PocketRocket is offline   Reply With Quote
Old 01-24-2009, 09:30 AM   #2
sosidge's Avatar
Your ESC should be able to handle the motor, a quick google search threw up a limit of 15 turns.
Gear ratio is very important. What gears do you have on the car now? The car's manual or one of the experts in the Schumacher thread should be able to tell you the internal ratio of your car, it is then a case of doing some maths...
FDR aka Overall ratio = Internal ratio*(spur/pinion)
www.sosidge.com - www.muchmoreracing.com
Old 01-24-2009, 09:34 AM   #3
i have a 89 teeth spur gear and a 24 teeth pinion....
--Schummacher mi2--
--Reedy Challenger 19t--
--Honda Nsx custom carbon fibre paint shell--
Old 01-24-2009, 09:41 AM   #4
dameetz's Avatar
Heres the link to understand FDR http://www.robinsonracing.com/tips.html
If I ain't drivin' I ll be flyin'
dameetz is offline   Reply With Quote
Old 01-24-2009, 09:56 AM   #5
sosidge's Avatar
I can't imagine that this gear ratio will be overgearing the motor so the case of the overheating must be elsewhere.
Check that the car rolls freely and that the motor runs "normally" if it is out of the car. Check that there is air flowing over the ESC (no waterproof covers or anything like that.
Apart from that it is going to be very hard to work out what the problem is over the internet.
Old 01-24-2009, 10:03 AM   #6
i still think its a too powerful motor for my esc, my mate has a better one on sale and hes letting me try before i buy, i'll update this thread after i do it
--Schummacher mi2--
Old 01-24-2009, 10:44 AM   #7
joe of loath's Avatar
how hot does it get? does it actually cut out? or does it just feel hot? hot is fine, but cutting out is pretty bad.
HPI E-Firestorm - Traxxas Revo - Tamiya TA05 - Custom built TC
Pastafarian and proud.
a_main_attendee: don't be dissing ma spinnin doritos dawg!
joe of loath is offline   Reply With Quote
Old 01-24-2009, 12:04 PM   #8
it just goes normal then it just slows down and stopped instanly...
--Schummacher mi2--
Old 01-24-2009, 12:19 PM   #9
bs6ef's Avatar
hey PocketRocket
what pully are you using, 20 or 17?
If you are using a 17t pully then your gear ratio will be 7.86 using a 89/24 spur pinion combo.
If you are using a 20t pully then your gear ratio will be 6.68 using a 89/24 spur pinion combo.
If you want i can email you a program that you can use to calculate your gear ratio, just drop me a pm
Steve
You have to watch the TechnoViking http://www.youtube.com/watch?v=_1nzEFMjkI4
bs6ef is offline   Reply With Quote
Old 01-25-2009, 10:30 AM   #10
Originally Posted by bs6ef View Post
hey PocketRocket
Steve
whats a pully, sorry i'm really new to the hobby
--Schummacher mi2--
Old 01-25-2009, 01:43 PM   #11
revo523's Avatar
The pullys are the other gears on your car the front and rear.
Xray T2 009 EU Tekin RS PRO Novak 13.5 SMC 5200
Team Magic G4JS O.S.12 skyline 12plus
Spektrum DX3S
What came first the chicken or the egg?
revo523 is offline   Reply With Quote
Old 01-25-2009, 02:20 PM   #12
bs6ef's Avatar
i was refering to the centre pully
Old 01-26-2009, 12:56 PM   #13
ahhh, yh i know what u mean now, its 20t...sooo
--Schummacher mi2--
Tags
gearratio , lrp , overheating , reedy , schummacher
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
