Veteran TAMIYA TA03 fans!
#1337
TA03TRF-PRO DJ Special Edition
Hi All,
This is for a specific market... Mint condition never driven just out of storage
Not going to blab on, if you know what your looking at and want this piece of Tamiya history, feel free to contact me with a serious offer.
When in storage was silica gel/bubble wrapped.
Any questions ask away
#1338
still runs pretty good
#1340
Ta03 setup sheet please
HI guys: I've been running the Ta03 at the local asphalt track, and would like to get it set up properly. Last week I had 55wt oil in the shocks, and that was way too stiff since the track is kinda bumpy.
I suspect my setup is just all wrong. Does anyone have an old setup sheet to share? I am not drifting, this is for normal touring car driving.
Thanks!
Jerry
Thanks!
Jerry
#1341
Thanks!
Jerry
Thanks!
Jerry
#1342
1. The car doesnt turn left very well. Turning right is fine. Im running stock camber links ,so maybe its my steering or toe.
2. the car gets wobbly at high speed, so I cant enter the corner properly.
I'mr unning street jam shocks, recommended by a hobby shop. Apparently they are similar to the tamiya aluminum dampers :
http://rc-art.net/product_eng/4562226710928
The springs are blue tamiya in the front, and yellow in the rear.
Im using sway bars (Yellow front, Orange rear)and i have carbon upper and lower decks with a lipo. Motor is in the front, since my car is a tao3F. Im running sweep or ride 36 tires usually.
One last question: I have the plastic SP-703 ta03Pro J parts battery holder , and it works fine to hold my(Square) lipos, however, I dont have a good way to keep the battery from sliding sideways since the side pieces are designed for oval batteries. What solutions are people using that allow you to change batteries fairly easily?
Id buy the Carbon fiber battery plate set if that would help, but I dont see any side holders/doors on that one either.
Thanks! Jerry
#1343
#1344
I just win an ebay auction an get mine pictures soon
#1345
Id like to fix two issues:
Thanks! Jerry
Thanks! Jerry
#1347
#1348
I never had much luck with front motor configuration. With mid motor setup, rear wheels don't hop around like front motor, and the car drives like it's on rails. If you're using stock gear diff, ball diff helps with the rear hopping. I use battery tape to hold the battery down.
Thanks! Jerry
Thanks! Jerry
#1349
You need to check the lengths of your tie rods. If you have your manual the pictures are real size to compare. I would also make sure your servo is centered. From there I would experiment with the springs. If you have too much steering now swap the shocks from front to back and see what happens.
#1350
Hi guys,
I recently got a TA03f and want to make it a drifter. Do you know any other pulleys that I can replace the std ones with?
