Old 10-09-2001, 12:42 AM   #121
erap's Avatar
Send a message via ICQ to erap
u can actually wire it in series. that would actually result in placing a motor with 6 turn motor limit on the roost. i think the roost can still handle it but i'm the type of person who thinks that its always better to be safe than sorry.
Originally posted by porkybmx
aw, then why have twin 11turns if your not going to wire it in series? Hehehe. Go with the tekin or lrp, they will fair much better that the super rooster. And the lrps are around 120, w/ the reverse i think im not sure, and the tekin is around 120 also.
erap is offline   Reply With Quote
Old 10-10-2001, 07:55 PM   #122
porkybmx's Avatar
Send a message via AIM to porkybmx
i apologize everyone, i was reading through the thread and i ran across an error, on my part. I said i used 29-30 pinion for stock motors, that is like kinda way off. I have in my car right now a 23. And i use a range of 23-25. What do you guys use for mod motors? I hope you guys have .4 module...
thanks
porkybmx is offline   Reply With Quote
Old 10-10-2001, 10:09 PM   #123
zxt
zxt's Avatar
Default question
how do I know if i have a.4 module? I use 19 for stock motor...isn't 25 too large? 14 is the stock right?
zxt is offline   Reply With Quote
Old 10-10-2001, 10:42 PM   #124
erap's Avatar
.4 module has small teeth, same as 64 pitch.
zxt: what you have are the .6 module gears
Old 10-12-2001, 05:59 PM   #125
For Stock racing PK2 I am using a 25 tooth .4 pinion gear. I gear my 17T double with 23 tooth .4 pinion gear.
Dayten is offline   Reply With Quote
Old 10-16-2001, 12:06 AM   #126
porkybmx's Avatar
keep this thread alive, it doesnt belong in the rctech boonies! Hows everyone's car running???
Old 10-16-2001, 02:26 AM   #127
Manuel's Avatar
Hi guys
does anyone have any Cross parts on their ta03's?
i may get the carbon damper stays tomorrow...cant decide
Manuel is offline   Reply With Quote
Old 10-16-2001, 04:14 AM   #128
My 03f DJ is still holding strong. I have won every A-main at Hobby Town USA race that I attended. Just to make everything even I ran the style 19T Spec motor that some of the other guys where running and same 2400 battery packs. The 03 was still as fast as the other TC out there especially the TC3's that where out there. Every since I bought my 03F DJ (used) it has over 10 victories and never finished lower than third at any of the local raaces.
rowdyrj is offline   Reply With Quote
Old 10-16-2001, 09:24 AM   #129
zxt
zxt's Avatar
Default Uhm...
Porky: I'll retain my 03R and sell both my 03F...
I'll post details soon...
By the way...how do I fix the slop in my FF-01? I cant seem to find the problem...I already change the servo but still my FF-02 continues to turn right if I turn right and left if I turn left...
Old 10-16-2001, 01:23 PM   #130
porkybmx's Avatar
hey, if there is steering slop, take some o-rings and slip them under the ball pivot, and if you dont have ball pivot then buy the machine sleeves that go in the fixed camber links
Old 10-16-2001, 11:32 PM   #131
zxt
zxt's Avatar
Default Thanks Porky...
I rebuild the steering section of the car and it looks like I fixed the problem...I'll do the o ring thing later...
Old 10-17-2001, 07:35 AM   #132
Default TA03Pro DJ
Hi All, I'm about to buy a used DJ just to play around. I was wondering if it can really keep up with the other cars around. Do I need to change anything on the car? I heard that in order to get better steering, I should change the TA02 caster blocks.
Also, how much should I be paying for a used DJ (condition: Good)?
Ivan is offline   Reply With Quote
Old 10-17-2001, 08:14 AM   #133
I would not pay more than $120 for a used DJ and make sure that everything is good.
Old 10-17-2001, 09:24 AM   #134
zxt
zxt's Avatar
Default DJ
Whats the difference bet a regular 03 and an 03DJ?
Old 10-17-2001, 09:49 AM   #135
The difference is the Chassie, shocks, belt, and pitch of the gears.
The 03F DJ has the Carbon chassie, aluminum shocks, narrow belt, 63 pitch white gears, sway bars, and aluminum motor mounts, and full ball bearing. and the car has the belted A-tires.
Where as the regular 03 has the tub chassie, plastic shocks, bushings and cheaper tires.
Veteran Tamiya TA02 fan chappi Electric On-Road 88 07-28-2015 07:38 AM
Tamiya TA03 hermanchauw Singapore R/C Racers 16 02-04-2009 05:14 AM
WTB: Tamiya TA03 -Jimmy- R/C Items: Wanted to Buy 1 02-13-2007 01:46 AM
TA03 help! or any tamiya fan! BrainTeased Electric On-Road 5 02-16-2004 01:35 AM
Tamiya TA03 hop-ups Evil_S10 R/C Items: Wanted to Buy 2 11-21-2002 02:13 PM
