Veteran TAMIYA TA03 fans!
#1261
Is the TA03F a narrow or an wide chassie.
How mutch offset can i use with an tamiya body?
#1263
The wheelbase on the TA03F is that moore like the Yokomo 258mm or like HPI 255mm?
#1264
TA03 is narrow. More like 180-185mm. It's even narrower than other tamiyas.
#1265
Thats music to my ears!
Love offset rims.
Love offset rims.
#1267
Anyone know what caster degree the Tamiya 49097, 53316, Cross TT-40, or GPM TA3020 front C hubs have? I know the TA02 hubs are 2 degree, but they don't have the sway bar mounts. I'd like a set intended for the TA03 that have 2 degrees instead of 8 degrees and are aluminum.
#1268
#1269
I'm going to put my TA03F pro back on the track in the VTA class. Our track uses 21.5 brushless. I am switching to the black .6 mod spur and counter gears for a little more reliability and better ratios with the brushless motor. With 1550g minimum weight it might be somewhat competitive. Main thing is I want to go have some fun without spending a ton on a new chassis.
My question is what differentials should I use? The track is high traction carpet. I was going to try out the one way diff up front, but I also want to try gear diffs. Should I keep a ball diff in the rear?
#1270
#1271
Sadly, many of the modifications I wanted to perform on my 03F pro would end up costing north of $100 once shipping is figured in. Pretty much the same cost as a new SpecR S1. So I'm going to clean it up, rebuild the ball diffs, toss on the aramid belt, some new control arms, install the TA02 hubs, and have some fun. If its remotely competitive, I'll consider performing some of the other items on my list. If not, I'll probably shelf it and pick up the S1.
#1272
TA03F retrofit?
I may be getting back into the hobby after more than a decade away. I dug this chassis out of my garage, basically a roller that I put together in 2005 and never had money (was in college at the time) for electronics, motor, etc.
The only battery packs I have are NiCds that are probably long since toasted. I believe I'll go with the new LiPo technology, if for nothing else than the longer run times. I haven't made a decision on motor yet, but brushless seems to be the way to go. So I guess what I'm getting after...
Is it a pain to retrofit the TA03F chassis to use LiPo packs, and can I fit the larger gear combos needed for the faster brushless motor?
#1273
I believe with the black gears you should be able to gear it low enough to use brushless, but I won't be able to verify that for a couple weeks.
#1274
Is it a tub or plate chassis? The plate chassis is pretty easy, just space the top of the battery holder up with some washers and use strapping tape instead of the original end retainers to hold the battery in place. I am working on another solution to replace the end retainers with lipo friendly versions so tape isn't required, but I don't have the materials yet as the car is in pieces for a rebuild. Tub chassis is a different issue since they were designed for rounded edge packs. Not sure what the solution is for those.
#1275
