Old 09-28-2011, 07:50 AM   #1216
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by ta03 tuner View Post
Good to know peeps are still using this chassis...probably my favorite touring car of all time...Use to beat Yoks, XXXs, Pro3s and TC3s in the Stock class all the time with it...I'm sure if I raced it today in the stock class, it could still compete. Biggest improvement was using the TA02 steering blocks...reduced caster gave it ALOT more steering as this thing tended to understeer with all the weight up front.
I'm with you as to this day the TA03 series of cars are still my favorite out of any type of racing I have done. I still have my TA03R-S TRF version that I won't sell. Have not ran it for years but still not for sale.
ST Racing Concepts (STRC)
Old 09-28-2011, 10:54 AM   #1217
Suspended
Originally Posted by peter p View Post
The .06 are the black gears the .04 are white,you can run 64p with the .04 but the .06 wont run 48p,the .06 need Tamiya pinions,if you are going to race it let me know as i ran my 03 pro on the weekend and know how to get them going
Ha, I ask because I`m going to make an front wheel drive car of it. Stupid idča I know but I want to race with it.
Yes my gears are white.
What is the biggest pinion 64dp that I can put in the car. And what is the final gear ration then.
Jerzi
PS Or shuold I sell this car and buy the ff03 pro instead
jerzi is offline   Reply With Quote
Old 09-29-2011, 02:32 AM   #1218
peter p's Avatar
I cant remember what the biggest pinion is but im sure with a bit of grinding you can get a 37 to fit,the main thing the ff03 has over the 03 is the weight of the drive train the ball diff is 29grm and the counter shaft is 17grm,so what i did was get a m03 yeah racing spool that is 17grm and a toby craft counter shaft that is 7grm and some aluminium cvds, all up the stock drive train is 66grm i got it down to 30grm.I dont know what the ff03 is but it cant be much lighter
peter p is offline   Reply With Quote
Old 09-29-2011, 10:49 AM   #1219
WC
WC's Avatar
Trader Rating: 28 (100%+)
i have heard somebody managing to install his pinion so that it drove the 'wrong' part of the spurgear... that would cutout some of the transmission's overall reduction!!
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 10-02-2011, 01:43 AM   #1220
peter p's Avatar
Hi all I have a 03pro that I want to make into a R,I know I need the B&E parts but it looks like you need a spacer under the front of the rear gear box that isnt on the B&E parts,I know it will fit the tub chassis but I have the FRP any help ? Thanks
Old 10-03-2011, 06:02 AM   #1221
Suspended
If I put the 37t (0.4dp) or 36t in my DAVID JUN car, what is the final gear ratio then.
Sorry dont have the manuel yet.
Jerzi
Old 10-03-2011, 06:53 AM   #1222
peter p's Avatar
Hi the internal ratio is 2.68, the spur is 63, with a 37p you will have 4.56, 36p 4.69 or 38p,4.44
Old 10-03-2011, 08:19 AM   #1223
Suspended
Thanks for the reply.
Is the 38t the biggest that fit in there.
Jerzi
Old 10-04-2011, 08:53 AM   #1224
WC
WC's Avatar
its just a lump of plastic
u can use a stack of 3mm washers or collars to replace it
www.PandaGFX.com
www.MelbRC.org
Old 10-22-2011, 06:54 AM   #1225
roberto_1029's Avatar
Send a message via Yahoo to roberto_1029
Default interchangeable?
I have a 3rd gen tamiya TA03F. im looking at converting it to brushless and upgrading some body components. Are all TA03 parts interchangeable between the different lines within that series like the R and MR?
roberto_1029 is offline   Reply With Quote
Old 10-22-2011, 05:41 PM   #1226
WC
WC's Avatar
how do you mean "3rd gen" and what is "MR" ?
afaik there's only 2 variants x 2 flavours
TA03F = front motor, TA03R = rear motor
modular "motor" gearcase is the same both ways
R & F have their own unique dummy (no motor) gearcases,
different tubs that change battery location.
TA03FS & TA03RS = short wheelbase (shorter tub & belt)
Plate chassis (FRP or CF) come in F, R or FS/RS.
Plastics can come in grey or black, same part #s.
www.PandaGFX.com
www.MelbRC.org
Old 10-22-2011, 06:53 PM   #1227
When I put in the model number on the tamiya website that what it came back with. It is the front mounted motor with belt driven 4 wheel drive. It still pretty much original other then a different motor installed from about 10 years ago. I really want to get rid of the heat sink and Old school brushed motor with speed control and drop in a brushless motor and ESC. so my real question is that if I were to order parts for the ta03 will it fit or are there certain key things that I should look for when ordering parts for this model. I would hate to order parts that wont fit or are wrong. Im just getting back into rc after a very long hiatus
Old 10-22-2011, 08:08 PM   #1228
gtfour93's Avatar
Trader Rating: 22 (100%+)
I converted my TA03F-S to brushless without any modifications. I'm using a Hobbywing EZRUN 35A ESC & 13T motor combo.
www.activrc.com
gtfour93 is offline   Reply With Quote
Old 10-23-2011, 04:35 AM   #1229
WC
WC's Avatar
ahh ok... front motor = you've got the TA03F
std wheelbase is ~259mm (axle to axle) and if its a lot shorter than that
then you've got the TA03FS like pictured immediately above
Before you do anything, check that your car has full Ball Bearings.
Every moving part in the transmission has to be supported by BBs,
it needs various # of size 1150, 1510, 1260, 850 & 730.
It would be best to buy a BB kit suited for TA03... F or R doesn't matter.
TA03 has beefy drivetrain which survives any "reasonable" brushless fine.
EZRUN 13T like above is barely more powerful than a Sporttuned brushed;
you could even go EZRUN 9T... note EZRUN are smaller than std motors.
With a std-size motor maybe don't go lower than say 8.5-10.5T.
Best change the pinion to a steel aftermarket unit,
stock tamiya aluminium is too soft & wears out fast.
Once worn it'll damage the other gear too.
With TA03 parts, all parts (except for the F or R-specific bits obviously)
will fit all cars but there's not many hopups that make worthwhile difference.
Std CVA plastic oil shocks work well when built right,
Tamiya TRF alloy shocks are the ultimate if you want an upgrade.
Universal driveshaft is worthwhile, these are same as TA02 front.
Best 03F hopup is probably the "koala nose" bumper shown above.
This takes some of the impact, if the 'blade' on the motor case takes
the full brunt then the motor can shift forwards & ruin gearmesh.
www.PandaGFX.com
www.MelbRC.org
Old 10-23-2011, 10:06 AM   #1230
thanks for all th info, thats why I came here to post. Hopefully I will be posting before and after picks real soon
Veteran Tamiya TA02 fan chappi Electric On-Road 88 07-28-2015 07:38 AM
Tamiya TA03 hermanchauw Singapore R/C Racers 16 02-04-2009 05:14 AM
WTB: Tamiya TA03 -Jimmy- R/C Items: Wanted to Buy 1 02-13-2007 01:46 AM
TA03 help! or any tamiya fan! BrainTeased Electric On-Road 5 02-16-2004 01:35 AM
Tamiya TA03 hop-ups Evil_S10 R/C Items: Wanted to Buy 2 11-21-2002 02:13 PM
