Old 10-05-2001, 12:53 AM   #106
porkybmx's Avatar
Send a message via AIM to porkybmx
jonny-
If you want to make your transmission free and more efficent, buy some Boca Bearings secret weapons. Then coat the tranny gears w/ white lightning. You can find this lube in your local bike shop. It works great on my bike chains andworks well for me on the gear in my tranny too. hope this helps. My tao3r trf is still running strong, with the correct gear w/ the correct motor, the ta03 can keep up with some of the best.
porkybmx is offline   Reply With Quote
Old 10-05-2001, 07:07 PM   #107
Default Replacement parts
My LHS does not carry a lot of Tamiya replacement parts. I am looking to rebuild my Super Low Friction shocks (Aluminum Bodies), but I am unable to find a rebuild kit. I would like to replace the red O-rings and the Oil Seal (shock bladder). Is there other manufactures O-rings and Oil Seals I could use? Maybe HPI? Suggestions? Thanks..
Dayten is offline   Reply With Quote
Old 10-05-2001, 10:04 PM   #108
TRF-Powered's Avatar
Call Tamiya USA... they have all the replacement parts that you will ever need. it's 1-800-Tamiya-A. Call them... I got most of my replacement parts from them... since no hobby shop really stock that many parts at once.
But go to their website first to find the part number of the stuff you are looking for though... that will make your ordering easy and fast
TRF-Powered is offline   Reply With Quote
Old 10-06-2001, 12:01 AM   #109
zxt
zxt's Avatar
Default Hey Porky
What is the diff bet 03F and 03R aside from rear mount motor and front mount motor?
I have both and I think I'm going to sell one...
zxt is offline   Reply With Quote
Old 10-06-2001, 11:41 PM   #110
Default Replacement Parts
TRF-Thanks for the info. I would really like to support my LHS but unfortunately they only carry very little parts for Tamiya cars, that's why I wanted to know if other manufacture's parts might work with what I have. Well looks like I'll be giving Tamiya a call. Thanks again.
Old 10-06-2001, 11:59 PM   #111
no problem, Dayten....
Old 10-07-2001, 05:00 PM   #112
porkybmx's Avatar
Default HOORAY~
Finally i uploaded and resized the photos of my custom TA03R TRF:
Old 10-07-2001, 05:02 PM   #113
porkybmx's Avatar
another
Old 10-07-2001, 05:04 PM   #114
porkybmx's Avatar
one more
Old 10-07-2001, 05:12 PM   #115
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
Heeeeellloooo TA03 owners!!
Thinking of reviving my TA03R's. Currently running nitro but thinking of reviving one of my TA03's. A dual motor conversion should be fun to do. Let me know what you guys think and a good ESC for around $100. (Super Rooster? Can handle dual 11T's?)
Dan is offline   Reply With Quote
Old 10-07-2001, 06:50 PM   #116
porkybmx's Avatar
err..dual 11turns w/ a super rooster isn't a good idea. You should look into the tekin 420 or a LRP Pro Reverse. Your need to use a lower gear ratio to take advantage of the dual motors.
Old 10-07-2001, 07:11 PM   #117
erap's Avatar
Send a message via ICQ to erap
u can use 11 t dual motors on the supe rooster, just don't wire it in series.
erap is offline   Reply With Quote
Old 10-07-2001, 11:09 PM   #118
porkybmx's Avatar
aw, then why have twin 11turns if your not going to wire it in series? Hehehe. Go with the tekin or lrp, they will fair much better that the super rooster. And the lrps are around 120, w/ the reverse i think im not sure, and the tekin is around 120 also.
Old 10-08-2001, 11:21 AM   #119
Dan
Dan's Avatar
Thumbs up
Thanks for the input!
Didn't think the Super Rooster can handle such a load anyways. Parallel wiring, yeah....but I want to do in series.
Reason chose TA03 was easy dual motor layout and the car and diffs are literally bulletproof. Will also look for my old RCCA mag with the dual motor TA03 to see what else I should do with it.
Old 10-08-2001, 10:20 PM   #120
Default Setups
I would like to know what are some of your setups for a Jun. I have mine set to the following.
Rear Suspension
Oil: 30WT
Springs: Blue
Pistons: Two hole Teflon
Ride Height: 5mm
Front Suspension
Oil: 30WT
Springs: Blue
Ride Height: 5mm
Toe: 0 to 1 out
Pulley: 16 tooth front and rear.
Chassis: Saddle
Super Low Friction Shocks.
No sway bars.
I would like to get a baseline setup for smooth, preped, parking lot track. Thanks.
Veteran Tamiya TA02 fan chappi Electric On-Road 88 07-28-2015 08:38 AM
Tamiya TA03 hermanchauw Singapore R/C Racers 16 02-04-2009 06:14 AM
WTB: Tamiya TA03 -Jimmy- R/C Items: Wanted to Buy 1 02-13-2007 02:46 AM
TA03 help! or any tamiya fan! BrainTeased Electric On-Road 5 02-16-2004 02:35 AM
Tamiya TA03 hop-ups Evil_S10 R/C Items: Wanted to Buy 2 11-21-2002 03:13 PM
SEO by vBSEO 3.5.0
