Old 03-13-2009, 06:17 PM   #1141
gtfour93's Avatar
Trader Rating: 22 (100%+)
Well the TA03F-S is still new. It's the Corolla WRC kit. I built it along time ago but never used it. As far as hop-ups, I just have ball bearings, aluminum dampers with colored springs and pin type wheel adapters. I'm waiting on an FRP double deck chassis and adjustable camber and steering turnbuckle kits. I also made a sway bar set out of a clothes hanger, since they are discontinued from TAMIYA. I just copied the one from my TA03F Pro chassis. This car is more for fun and practices at TAMIYA track in Aliso Viejo.
www.activrc.com
gtfour93 is offline   Reply With Quote
Old 03-13-2009, 06:55 PM   #1142
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
Default Tamiya body
Originally Posted by gtfour93 View Post
I just revived both of my TA03s. Not much parts available anymore. What other TAMIYA or other bodies still available that will fit on the TA03F-S (short wheelbase) chassis?
Old tamiya M02L bodies fit with some mod. such as Honda S2000, Porshe 911, Porshe Boxter, BMW Z3, and Benz SLK. you need change your rear axle to narrower ones. I found that ultimate Hobbies in O.C has 4 of Benz SLK bodies in stock. or you can try Ebay
Phat-Boy is offline   Reply With Quote
Old 03-13-2009, 08:10 PM   #1143
gtfour93's Avatar
Thanks for the tip. I saw the MB SLK body as well, when I was there last time. Honda S2K and/or 911 would be nice.
www.activrc.com
Old 03-13-2009, 08:30 PM   #1144
Hyde's Avatar
yep works pretty well. just mocked up my m04l z3 body wheelbase is dead on. the rear pokes out tho looks a little funny with the two piece rims sticking out the body! and the rear will need straight body post to work aswell.
and yeah the 911 would look great. i remember i use to have a tech racing rear belt drive m02l with the 911 body. that thing use to fly
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 03-15-2009, 12:29 PM   #1145
jcr
I'm dusting off my TA03R, I heard the TA03 would make a good drift car. Any suggestions on the setup and tires? I think I saw a site that talked about setting up a TA03 into a drift car but couldn't find it anymore.
Current upgrades I have on the TA03, center one way (front) and 1 ball diff (rear) any suggestions on where I should put these two (front or rear or none)?
jcr is offline   Reply With Quote
Old 03-15-2009, 12:52 PM   #1146
Hyde's Avatar
take out the one way. keep the diffs the way they are. search "rc drift tires" on ebay.
rc drift tires are a very hard type of rubber. use them.
the susp' doesn't matter. springs don't matter much. there no type of "handling" to rc drift cars.
Old 03-15-2009, 01:11 PM   #1147
jcr
Wouldn't I want more grip on the front so a ball diff in the front instead of the rear?
Just don't remember the site that talked about drift setup on the TA03 it had everything.
Old 03-15-2009, 01:24 PM   #1148
Hyde's Avatar
a ball diff is an options for "grip" racing. a bill diff wouldnt have you drifting any better then if you had two gear diffs.
i heard locking the gear diffs so its a straight axle feel will have the drift more consistant.
you don't want the front to have more grip. it will fish tail like to crazy. you don't want more grip in the rear because it wouldn't turn right and wouldn't drift where you want it to.
Old 03-15-2009, 03:51 PM   #1149
Trader Rating: 24 (100%+)
I think there's some confusion....the front diff should be a ball diff or a 1 way. If you run it as a limited slip diff start with it loose and tighten till your happy with performance. The rear diff should be locked. That way the rear wheels spin together and at the same rpm.
The 03 drifts great !
Evoracer is offline   Reply With Quote
Old 03-15-2009, 04:28 PM   #1150
jcr
ok thought the ball diff should be in the front. For the center one-way, should it be in the front or rear? Don't know the different in that.
Old 03-16-2009, 05:32 AM   #1151
Sorry jcr...caught myself after I posted. There is no center 1 way for the TA03. I corrected my post and hopefully that clears it up for you.
Old 03-16-2009, 01:50 PM   #1152
ShadowAu's Avatar
Yes there is a "centre" one way for a TA03... I think its actually sold as a torque splitter or something similar and it replaces the shaft and gear that meshes with the front diff
My car may look like it goes bad to you, but its actually far worse that you think it is...
I have only one more RC thing on my bucket list and I will keep racing (and probably coming last) till its done.
ShadowAu is offline   Reply With Quote
Old 03-16-2009, 03:02 PM   #1153
jcr
yes that's what I mean, a torque splitter. Would having that in the front help it drift?
Old 03-16-2009, 08:55 PM   #1154
Hyde's Avatar
what was the leading company going againts the ta03 back in 96? and even around when dave june was pounding the tracks with it.... HPI pro? pro2 pro3? any other companys?
Old 03-17-2009, 03:00 AM   #1155
Phat-Boy's Avatar
Yokomo YR-4 and Roadrunner Express. Yokomo was like todays Xray. it was top T.C. everyone thought TA03F was toy, but david jun shocked the world when he won back to back roar national and noccar i guess.
Veteran Tamiya TA02 fan chappi Electric On-Road 88 07-28-2015 07:38 AM
Tamiya TA03 hermanchauw Singapore R/C Racers 16 02-04-2009 05:14 AM
WTB: Tamiya TA03 -Jimmy- R/C Items: Wanted to Buy 1 02-13-2007 01:46 AM
TA03 help! or any tamiya fan! BrainTeased Electric On-Road 5 02-16-2004 01:35 AM
Tamiya TA03 hop-ups Evil_S10 R/C Items: Wanted to Buy 2 11-21-2002 02:13 PM
