Old 11-28-2008, 01:01 PM   #1111
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
Default ball diff
i try to rebuild ball diff for my ta03f dj. have any one tried tamiya 1/10 touring car aluminum ressure plate set (item #53219 or op219)? is it lighter then ta03 perssure plates? also anyone knows that where i can buy ceramic ball thrust bearings. i want to get 3mm ceramic balls and ceramic ball thrust beraings, but i can't find ceramic ball thrust beraings.
Phat-Boy is offline   Reply With Quote
Old 11-28-2008, 01:08 PM   #1112
ShadowAu's Avatar
Originally Posted by wyd View Post
I don't think you need alum a arms for the TA03 as they add a tad bit extra strength but add extra weight and the 03 is already a heavy car.
Not with lipo... running it with a Yeah racing or Orion 3200 and its actually underweight... by about 100 grams.... even with my MaxAmps 5000 pack it was still about 30 grams underweight...
I was more interested in whether or not the changed shock angle etc made a significant difference... things like that
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is offline   Reply With Quote
Old 11-28-2008, 02:27 PM   #1113
I12PonU's Avatar
Trader Rating: 10 (92%+)
They are much smoother and dont feel lumpy. You can also set the diff looser than the stock 03 balldiff.
I12PonU is offline   Reply With Quote
Old 11-28-2008, 05:05 PM   #1114
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I forgot about the lipo thing. I have not ran mine for years and lipos where not popular at all back then.
It shouldn't change the shock angles at all from looking at them. Most of the aftermarket arms I have seen are just copies of the stock ones with no angle changes.
ST Racing Concepts (STRC)
Old 11-29-2008, 04:13 PM   #1115
ShadowAu's Avatar
There are some pics of the fitted on RCMart and it appears the shock hole is right beside the outer pivot.... which will give the shock a nice lean in at the top... which should give the shock a progressive feel (I think)
Old 11-29-2008, 06:11 PM   #1116
wyd
Tech Legend
wyd's Avatar
The aluminum ones I had where directly like the stock plastic ones. The pic of the one you posted do have some angle. I actually like the setup you posted. I like that little bit of extra angle. Would be fun to try a set of those sometime.
Old 12-18-2008, 07:39 PM   #1117
TA03 that still runs well on carpet racetrack
AE B44 * TA03 * Nitro RS4 * Micro RS4 * HOR * 3PK 2.4G
- - - - - - - - - - - - - - - - - - - - - - - - - - - Paquito I.
kitz is offline   Reply With Quote
Old 12-19-2008, 10:35 PM   #1118
Phat-Boy's Avatar
Thumbs up ta03 spec
what kind lipo and brushless motor are you running? gearing choice?
what happen to top deck? is it for chassis flex mod? just kidding.
Old 12-22-2008, 10:57 PM   #1119
Lipo: SMC 4000
Motor: SP 4.5
Spur: 65
Pinion: 16
A car ran over it during a test run on the street.
Old 12-23-2008, 02:19 PM   #1120
I12PonU's Avatar
You run this setup on carpet? Does it traction roll? How many o rings do you have inside the shocks? Cant get mine to stop flipping.
Lipo: SMC 4000
Motor: SP 4.5
Spur: 65
Pinion: 16
Old 01-06-2009, 01:06 PM   #1121
Default Converting an 'R' to an 'F'
Back in the day, My father and I had TA03's. I had an R and he had an F. I just recently found 2 NIB TA03-r's and bought them both. But what I can't find to save my life is an F.
So, I got to thinking. A buddy of mine has a crap ton of old Tamiya parts, and I thought, 'aren't most of the parts interchangable?' If anyone could help me out on the parts list that I need, I would appreciate it very much. His B-day is coming up soon and I want to surprise him with it.
Cmunky is offline   Reply With Quote
Old 01-06-2009, 02:35 PM   #1122
ShadowAu's Avatar
Basically should only need the F gearbox trees... front and rear... everything else is the same... the only hassle might be is the F had a low profile shock tower for use on modern bodies which might be harder to get now
Old 01-06-2009, 08:15 PM   #1123
vlozity's Avatar
Cmunky, you forgot to mention what kind of chassis you have ... are they tub or carbon fiber?
anyways, the R's are easy to convert, you just need the rear 03F gearcase (B Parts #50699) to convert it. just move the TA03R's rear gearcase to the front, make sure you have the motor guard (A Part (#50698) No.3 in the tree).
the Reinforced Damper Stay (Low Mount Type - Part #53337) isnt really a necesity. i think rcmart still has them on stock, they have the rear gearcase too last i checked ... in gray though.
hth!
3Racing Sakura D4 RWD & AWD converted to RWD
Tekin RS ESC Tekin Redline 13.5T BL Sensored Savox 1257TG Sanwa MT4
vlozity is offline   Reply With Quote
Old 01-06-2009, 08:29 PM   #1124
vlozity's Avatar
btw, i just rebuilt my runner ... a good friend bought it recently.
Front Gearcase
Rear Gearcase
front and rear top angled shots
thanks for looking!
Old 01-07-2009, 10:53 AM   #1125
BobbyS's Avatar
Very nice! Are those the Cross parts?
"After the third flip, I lost control............"
BobbyS is offline   Reply With Quote
Veteran Tamiya TA02 fan chappi Electric On-Road 88 07-28-2015 07:38 AM
Tamiya TA03 hermanchauw Singapore R/C Racers 16 02-04-2009 05:14 AM
WTB: Tamiya TA03 -Jimmy- R/C Items: Wanted to Buy 1 02-13-2007 01:46 AM
TA03 help! or any tamiya fan! BrainTeased Electric On-Road 5 02-16-2004 01:35 AM
Tamiya TA03 hop-ups Evil_S10 R/C Items: Wanted to Buy 2 11-21-2002 02:13 PM
