Old 11-04-2008, 03:53 AM   #1096
ShadowAu's Avatar
I have all the ta03 bits... just looking for other ideas to increase cooling
My car may look like it goes bad to you, but its actually far worse that you think it is...
I have only one more RC thing on my bucket list and I will keep racing (and probably coming last) till its done.
ShadowAu is offline   Reply With Quote
Old 11-04-2008, 10:22 AM   #1097
BobbyS's Avatar
For cooling, the aluminum plate that goes inside the motor housing and the aluminum gear case cover both help some.
The standard (black .4 pitch) gears are great for getting low gear ratios - 43/35 * 3.055 = 3.75, and they can take crashes.
Also very stable on rubber tires/carpet when using tire prep, e.g., paragon fx.
"After the third flip, I lost control............"
BobbyS is offline   Reply With Quote
Old 11-05-2008, 10:33 AM   #1098
BobbyS's Avatar
Body shell for above...
Old 11-05-2008, 10:42 AM   #1099
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
Default ta03rs
nice ta03rs you got there. what kind of battery are you using in bathtub?
i got nimh 4200mah stick pack, but too tight. so i'm using 3300mah stick pack for bathtub chassis.
Phat-Boy is offline   Reply With Quote
Old 11-05-2008, 10:59 AM   #1100
BobbyS's Avatar
Hmmm, to be honest I've been running some old 2000 nicd stick packs in it, but I have new Trinity 5000 nimh Reference packs that I had planned on running Sat. Now am wondering if they'll even fit. Will have to try them tonight!
Old 11-05-2008, 07:24 PM   #1101
Dan
Dan's Avatar
Trader Rating: 43 (100%+)
Keep us updated if they fit. I'm trying to see if I can get away with a lipo hardcase pack I have coming in for the tub chassis, but I do have the graphite chassis conversion as a last resort.
Dan is offline   Reply With Quote
Old 11-05-2008, 08:26 PM   #1102
BobbyS's Avatar
It fit both the tub and CF chassis' with room to spare!
Would be interested in what LiPo's you guys are using...
Old 11-05-2008, 11:02 PM   #1103
I12PonU's Avatar
Trader Rating: 10 (92%+)
Care to share your setup? I have tried running an 03r on carpet and didnt have much luck.
Originally Posted by BobbyS View Post
I missed a chance to take it out this past weekend, but hope to bring it (ta03rs) with me to try on our carpet setup this week. In the past, it's always been very stable on rubber tires/carpet when using tire prep, e.g., paragon fx.
I12PonU is offline   Reply With Quote
Old 11-06-2008, 01:29 PM   #1104
BobbyS's Avatar
The only change I make to the kit setup is that I use 50wt oil in front and 30wt oil in back. (normally 25/25.)
Old 11-07-2008, 06:39 AM   #1105
Hi everyone,
I have a TA03F lying around from years ago, it is fully built up but in sore need of a rebuild. It has been collecting dust ever since I shifted. Everything is stock... (MSC, stock motor etc.)
I am thinking of rebuilding it from ground up but with much nicer parts then what I currently have, I have seen some of the builds in this forum and they look very impressive. I also have a Futaba T3PDF with a broken antenna, any idea where I could find one?
Would it be more worth it to buy hop up parts for it? Or look out for another complete car and cannibalize the parts from there? What are the costs involved? I am not looking to race or anything like that, just want a good looking/ relatively quick car that I can take out every now and then for some fun.
If I rebuilt it, what parts should I be looking out for first? ESC? New motor? One of those sweet graphite/CF chassis?
Anyone can point me in the right direction? Many thanks in advance!
doubletaps is offline   Reply With Quote
Old 11-07-2008, 07:20 AM   #1106
minimusprime's Avatar
Trader Rating: 19 (100%+)
i've got 3 tao3's sitting on the shelf. 1 tao3 dj edition, 1 tao3r-trf, and one that is fully optioned with top racing and kawada aftermarket parts.
From my experience you'd be better off canabalizing another car. You can upgrade it but then it's just going to shift where the breaking point on the car is and you'll have to upgrade that part. For example, On the rare occasion that I do break a part on one of the ta03's it's typically the lower hinge pin holder or something because i have aluminum a-rms, hubs, and hub carriers on the front ad rear.
The only thing I would really look at doing would be replacing the tub chassis. I snapped 2 plastic chassis when i tried to convert the ta03 dj edition to a rally car and run it around. Granted i did so jumping it off 18" jumps but from my experience that's the weakest point on the tub cars. Everything else is built like a tank.
for electronics I'd go for a 19turn or 10.5 or 13.5 (4300-5800kv) from my experience these cars do have a decent amount of drag and gearing is some what limited. That makes it difficult to run 17.5s 21.5's and even 13.5 some times. If you do actually want to race it get some of the tamiya .04 module black gears or dig up a robinson racing 48p conversion (I use this on all my ta03's) this will allow you to hit the lowe final drive ratio's you need to make the motor run where it needs to. Otherwise you can just scoop up some freshly rebuilt co27 stock motors or 19 turns on the fs/ft forum for super cheap (10 bux a piece) and 4 of those will outlast the car.
gl
"I personally do not believe in luck. I believe luck is just an excuse for people that have failed in their mission to accomplish something." Allen McNish
minimusprime is offline   Reply With Quote
Old 11-07-2008, 10:45 AM   #1107
BobbyS's Avatar
TA03R with carbon fiber chassis.
Old 11-26-2008, 12:20 PM   #1108
ShadowAu's Avatar
Hey fellow 03 Racers... I've been having a ball with mine since bringing it back out of storage... and it actually handles better than my 415
Just wanted to know has anyone tried these - http://www.yeahracing.com/catalog/al...bu-p-2302.html
I've tried some of their other bits like the rear uprights and they seem to work well though there does appear to be more play in them generally.
I am actually thinking of trying to get as many spares/options together and continuing to run my 03 instead of buying a new car ... I am not going to be racing regularly in 2009 at this stage and can't be bothered spending big $$ on a new car that will hardly get used
Old 11-26-2008, 10:51 PM   #1109
Dan
Dan's Avatar
Finally got a pic of my TA03R. Need to do something about securing the lipo battery pack better. And yes...thats a zip tie holding it in.
Old 11-28-2008, 10:51 AM   #1110
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
I don't think you need alum a arms for the TA03 as they add a tad bit extra strength but add extra weight and the 03 is already a heavy car.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Veteran Tamiya TA02 fan chappi Electric On-Road 88 07-28-2015 07:38 AM
Tamiya TA03 hermanchauw Singapore R/C Racers 16 02-04-2009 05:14 AM
WTB: Tamiya TA03 -Jimmy- R/C Items: Wanted to Buy 1 02-13-2007 01:46 AM
TA03 help! or any tamiya fan! BrainTeased Electric On-Road 5 02-16-2004 01:35 AM
Tamiya TA03 hop-ups Evil_S10 R/C Items: Wanted to Buy 2 11-21-2002 02:13 PM
