Old 10-23-2008, 03:14 AM   #1081
Default Ball differentials...need two sets?
Hi,
So despite the warning, I have put some SLIGHTLY larger than normal off road wheels on my dusted off TA03F for running around the garden.
On a whim, I also bought a 'ball differential set' (part 53267) off eBay as it seemed cheap enough at $25. I'm now wondering if I should have bought two sets because clearly it's just for one gearbox. Nothing seems to suggest buying two - is that just meant to be common sense or is there a reason you only use a ball diff in the front or rear? I presume the benefit here is just like any ball bearings to make things run a little smoother and not for any change in driving characteristics.
natd is offline   Reply With Quote
Old 10-23-2008, 05:57 AM   #1082
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Use the diff for the rear and you can always upgrade the front later.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 10-23-2008, 10:46 AM   #1083
BobbyS's Avatar
Overall, the ball diffs allow for much smoother running/handling. The bevel gears are acceptable even though they tend to wear down and loosen over time. You do have the option of adjusting the remaining diff gear by packing it with either a lighter or heavier grease.
"After the third flip, I lost control............"
BobbyS is offline   Reply With Quote
Old 10-24-2008, 08:05 AM   #1084
Default TA-03 predecessor
Hi, I know- this is for TA-03s. I do have a TA-02.(couldn't find a TA-02 thread) Don
Veteran TAMIYA TA03 fans!-ta-02-001.jpg   Veteran TAMIYA TA03 fans!-ta-02-002.jpg   Veteran TAMIYA TA03 fans!-ta-02-003.jpg   Veteran TAMIYA TA03 fans!-ta-02-004.jpg
DLS II is offline   Reply With Quote
Old 10-24-2008, 08:40 AM   #1085
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Also, does anyone know if the Team Orion lipos fit the tub chassis?
Dan is offline   Reply With Quote
Old 10-27-2008, 01:14 PM   #1086
BobbyS's Avatar
Nice car, Don!
The original shaft drive car from Tamiya?
Old 10-27-2008, 02:49 PM   #1087
Thanks! I enjoyed making the chassis. The TA-02 was preceded by the TA-01. The TA-01 chassis is still used in the Hummer. Don
Old 10-27-2008, 06:32 PM   #1088
I wonder how a TA-03 or even the 02 would do in VTA....Has anyone tried.
cherokee is offline   Reply With Quote
Old 10-27-2008, 07:23 PM   #1089
minimusprime's Avatar
Trader Rating: 19 (100%+)
i thought about it since i have 3 of them sitting on the shelf. gearing a 17.5 or 21.5 would be rough. you'd have to run a co27 to stand a chance i think.
"I personally do not believe in luck. I believe luck is just an excuse for people that have failed in their mission to accomplish something." Allen McNish
minimusprime is offline   Reply With Quote
Old 10-28-2008, 04:22 AM   #1090
I'm still thinking about it. You've got to have the speed tuned gear set and use the 66T. Get the 28 & 29 pinions from HPI (E-10-.6 module) and you have 5.75-5.55 gearing. The rest is just bolting on wheels,tires and mounting a TA body of your choice. Don
Old 10-28-2008, 08:08 PM   #1091
BobbyS's Avatar
Bump!
Old 10-29-2008, 10:50 AM   #1092
BobbyS's Avatar
Pic of an update I made to my TA03 using an old TC5 P-DUB bumper. Not pretty, yet, but more functional than the optional Tamiya foam bumper. The glue is between the foam and a strip of double-sided tape that holds it to the base plastic bumper (same as the option foam.) Only needed the glue to fill the gaps that I left when I did the hack job. A cleaner cut will eliminate the need for it. The P-DUB bumper is stiff, and wide enough to protect the wheels/front suspension. Would have been better if I'd spent more time in cutting it to fit the contours too, but not bad for a first swag. It currently fits a Tamiya NSX body just right.
Old 11-02-2008, 06:06 PM   #1093
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
Default ta03f spool
have anyone tried spool in front?
i may try to run tcs gt1 class next year with ta03f dj.
Phat-Boy is offline   Reply With Quote
Old 11-03-2008, 10:34 PM   #1094
ShadowAu's Avatar
I haven't yet but if it doesn't get rained out again I should be soon... not sure if it will be better than the 2 diffs I run now
Has anyone come up with any practical ways of keeping the motor cool in a TA03F... I am expecting to be racing in 30+C the next few meetings and I think cooling could be a premium... I am running a 10.5
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is offline   Reply With Quote
Old 11-03-2008, 10:56 PM   #1095
Phat-Boy's Avatar
Default heat sinks
i'm using ta03 aluminum heat sink (#53275), ta03 aluminum motor plate (#53357, and ta05 aluminum motor heat sink (#53837) witch i cut 2/3 to make it fit on back of motor.
Veteran Tamiya TA02 fan chappi Electric On-Road 88 07-28-2015 07:38 AM
Tamiya TA03 hermanchauw Singapore R/C Racers 16 02-04-2009 05:14 AM
WTB: Tamiya TA03 -Jimmy- R/C Items: Wanted to Buy 1 02-13-2007 01:46 AM
TA03 help! or any tamiya fan! BrainTeased Electric On-Road 5 02-16-2004 01:35 AM
Tamiya TA03 hop-ups Evil_S10 R/C Items: Wanted to Buy 2 11-21-2002 02:13 PM
