Old 02-13-2005, 04:31 AM   #901
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
They are fun cars to run. A little dated but against other Tamiya type cars they do well. I have a TA03R-S TRF version. I run it mainly at TCS races. I always have alot of fun running it. Lots of good stuff on Ebay for those cars to.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 02-13-2005, 10:41 AM   #902
Thraex's Avatar
Wow the TA03 chassis, I used to have the RS TRF...
in my earlier days!
In those days the TRF (404,414) cars burned A hole in your pocket and they weren't even TCS legal!
I Honestly miss it!
It's great to hear people still race with it,
I always loved the car, too bad I don't have it anymore
Back in the days I still drove it I was thinking making A twin motored TA03, Combining the R with the F (or vise versa).
Though I never tried it, but I think it should be possible.
Do you guys think that could be done, and does someone ever tried it?!
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 02-13-2005, 06:02 PM   #903
rough512's Avatar
It has been done. tRY reading through this thread. A picture has already been posted before(around 2002)
rough512 is offline   Reply With Quote
Old 02-13-2005, 06:12 PM   #904
wyd
Tech Legend
wyd's Avatar
I think a magazine did an article on that one time.
Old 07-17-2005, 02:41 PM   #905
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
Default help
hello to all guys here.. im also a big fan of ta03..
guys i need your help.. im running on a stock class of johnson 540..
i need some help about gearings.. my car is ta03r-pro..
can someone help me with this gearings..
my gear is 64pitch, and i cant find the right pinion to get great acceleration & full speed for johnson 540..
hope u could help me.. thanks very much.. hope someone will reply soon..
nikkiesteban is offline   Reply With Quote
Old 07-17-2005, 06:33 PM   #906
wyd
Tech Legend
wyd's Avatar
Man when I ran the stock silver motors I ran a huge pinion gear to make it fast. I ran 33 with the stock 63 tooth spur. It is alot of gear but it made the 540 scream. It will get hot but when I ran GT-3 with mine and geared it hard.
Old 07-18-2005, 01:30 AM   #907
is that the top speed and acceleration for ta03?
Old 07-18-2005, 05:05 AM   #908
wyd
Tech Legend
wyd's Avatar
Running with the silver can you need good corner speed to run that type of gearing. If you don't have any corner speed that type of gearing won't be fast. IN the straight it will rip and bog some in the corners but thats where good corner speed comes in to play. IT is hard to make these cars fast with a silver can because of all the gears on the 03 but you can get going pretty quick.
Old 07-18-2005, 05:15 AM   #909
but can u details it.. for example.. xxx pinion teeth, xxx spur teeth and xxx ptich.. tnx again
Old 07-18-2005, 08:10 AM   #910
wyd
Tech Legend
wyd's Avatar
I ran a 33 tooth pinion with the stock standard 63 tooth spur all in 64 pitch. I think that made my rollout around 33mm or so with the silver can.
Old 07-19-2005, 03:24 AM   #911
ohhh.. hows the speed..? was it fast? tnx again...
Old 07-19-2005, 11:26 AM   #912
wyd
Tech Legend
wyd's Avatar
I had the speed but like any car with lots of gears it is still some work to keep upp witht he newer Tamiya 04's and the new 05 as they are lighter and have less gears. Overall I held my own and did well.
Old 07-31-2005, 04:12 AM   #913
Default gearing.
hello to all guys again.. im here again..
i have a problem with my tao3r-pro.. it not that fast.. what gearings that u should suggest me... tnx.. im using 540 johnson.. i want full topspeed and acceleration..
Old 07-31-2005, 04:33 AM   #914
wyd
Tech Legend
wyd's Avatar
Well you won't have great acceleration with those motors and the type of gearing you need to be fast. To be fast you need gret corner speed. To be fast with those motors you need to have a great efficient working car. Then you can be rewarded with a fast car. Now it is going to be hard with a 03 as in general they are not the most effiecient cars out their since they have so many gears and a belt.
You need to make the transmissions as free as possible and keep the belt tension as loose as ou can with out it coming off.
Old 08-16-2005, 12:48 AM   #915
fabolousRC's Avatar
Send a message via AIM to fabolousRC Send a message via Yahoo to fabolousRC
From Tamiya.com website:
Tamiya is re-releasing TA03F-PRo as a drift kit. It features the same components as the original plus new spring kit, new wheel design and new tires design. The picture showed TT-302BK ESC on it but most likely it will available as an optional equipment only.
Here is a rough translation from Tamiya.com:
Item No: 49377
TA03F PRO drift specifications chassis kit
Total length = 388mm
RC limited series - TA03F PRO DRIFT SPEC CHASSIS KIT
* Front motor & belt whose stability is high drive 4WD, TA03F ・ PRO was finished in drift specification. * Equipping the private tire of special cross section. * Completeness equipment charm e.g., light weight high rigidity the FRP make double deck frame, full bearing specification, the ball diff. is equipped on front and back. * The responsiveness for load movement is high, can enjoy drift travelling with ease.
fabolousRC is offline   Reply With Quote
Veteran Tamiya TA02 fan chappi Electric On-Road 88 07-28-2015 07:38 AM
Tamiya TA03 hermanchauw Singapore R/C Racers 16 02-04-2009 05:14 AM
WTB: Tamiya TA03 -Jimmy- R/C Items: Wanted to Buy 1 02-13-2007 01:46 AM
TA03 help! or any tamiya fan! BrainTeased Electric On-Road 5 02-16-2004 01:35 AM
Tamiya TA03 hop-ups Evil_S10 R/C Items: Wanted to Buy 2 11-21-2002 02:13 PM
