Veteran TAMIYA TA03 fans! >
Like Tree18Likes
Old 09-16-2001, 04:40 AM
  #61
r32
r32's Avatar
To correct traction rolling, try more negative camber, reduce your ride height, and also try using tires which are a bit less grippy. Or you can try to put all your electronics on the lower deck of the chassis.
r32 is offline
Old 09-16-2001, 09:41 PM
  #62
Default Body and wheels
Great forum for TA03 fans. I have a question. What bodies are you guys running? Hpi or Protoform? Also what offset on your wheels are you guys using? I am running a TA03F Pro. Thanks in advance.
Dayten is offline
Old 09-16-2001, 10:36 PM
  #63
zxt
zxt's Avatar
Wink Tamiya bodies
all of my bodies are Tamiya...I have to Skyline GTR (Calsonic and Kure) I also have Castrol NSX...
2+ offset...
Now for my question...since I cant find any forum about radios...what can u say about Airtronics compare to Futaba? Also whats the diiference bet AM 75mhz and AM 27 mhz if theres any...
zxt is offline
Old 09-16-2001, 11:25 PM
  #64
TRF-Powered's Avatar
Any radio that feels good to your hand is a good radio.
I have a Futaba 3PDF and I can't complain anything about it. it's light and it got every function that I'm looking for. So It's a good radio for me.
A lot of people are going for Airtronics M8 cuz it's a great radio too. It really depends on your own prefrence.
I have weird prefrence when comes to RC. I go for everything Japanese. ESC: Keyence. Radio: Futaba, Car: Tamiya, Servo: Futaba..... Even though they are not all made in Japan. But for some reason I just go for Japanese product most of time....
TRF-Powered is offline
Old 09-17-2001, 04:40 AM
  #65
zxt
zxt's Avatar
Default 75mhz vs 27 mhz
thanks...
still i want to know if theres aq difference bet 27mhz and 75 mhz on AM Radios...
Thanks in advance
zxt is offline
Old 09-17-2001, 05:14 AM
  #66
tiburshok's Avatar
r32: thanks; will try lowering the ride height. btw, from where do you measure ride height? is it from the chassis or the suspension arm? or whichever part is nearer the ground?
zxt: stock pinion of the regular (not pro) ta03f is 14 teeth
tiburshok is offline
Old 09-17-2001, 07:15 AM
  #67
porkybmx's Avatar
measure from the chassis
porkybmx is offline
Old 09-17-2001, 07:51 AM
  #68
zxt
zxt's Avatar
Default 14 teeth?
Damn...I got my TA-03F used and there's this 17 tooth pinion there...I changed it to 19 to pick up more top end speed...so changing it from 14 to 19...will u consider that as an over gearing? Is this bad for my motor? Anyways I still use the stock Jonhson that came with it...
Now if anyone can only answer my Radio ?'s...
zxt is offline
Old 09-17-2001, 03:07 PM
  #69
rowdyrj's Avatar
Default My 03F DJ
Here is a picture of my 03 fresh of a victory at HobbyTown USA in GA.
It's a HPI Dodge Stratus body.
rowdyrj is offline
Old 09-17-2001, 08:00 PM
  #70
tiburshok's Avatar
Default 03F pinions
zxt: it's ok if you change it to 19t... i use to run my johnson stock with 21t pinion...it runs ok...eric of ritchie ritz recommends 25t for maximum top end but i settled for the 21t for more runtime...now with the tamiya superstocks i'm using 22t (0.6) pinion.
Old 09-18-2001, 12:50 AM
  #71
erap's Avatar
TIBURSHOK: What are u doing here!!!!!!!
erap is offline
Old 09-18-2001, 01:03 AM
  #72
tiburshok's Avatar
Talking
erap: i feel at home here...being that an 03 i drive. hihihihi....
Old 09-18-2001, 01:06 AM
  #73
erap's Avatar
i post here for sentimental reasons...
erap is offline
Old 09-18-2001, 05:56 AM
  #74
zxt
zxt's Avatar
Default Tiburshok
ganda ng avatar mo ah...sino yan?
so okay lang pala yung 19T...
How do I compute for compression ratio?
zxt is offline
Old 09-18-2001, 08:29 PM
  #75
tiburshok's Avatar
zxt: secret....hehehe
what do you mean compression ratio? gear ratio maybe?
if gear ratio then, spur/pinion x diff gear/countershaft gear.
