Old 10-03-2002, 01:02 AM   #661
Steevo's Avatar
Default TA03F Pics
Here's some photos of my TA03 after my FRP chassis conversion. Also new addition of Novak Speed control and Trinity Team Kinwald 9 Turn. Its awesome.
I just have to set the ESC's current limiter to stop the massive wheelspin on takeoff. My new belted HPI racing slicks should help some once fitted.
Steevo is offline   Reply With Quote
Old 10-03-2002, 01:04 AM   #662
Steevo's Avatar
Default MORE PICS
some more
Old 10-03-2002, 01:05 AM   #663
Steevo's Avatar
another pic
Old 10-03-2002, 01:06 AM   #664
Steevo's Avatar
Last one!!
Old 10-03-2002, 09:24 AM   #665
psycho's Avatar
Steevo
The car looks good.
Dayten
You racing this Saturday? New venue. Should be interesting!
psycho is offline   Reply With Quote
Old 10-03-2002, 04:12 PM   #666
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Nice looking car. You should mill out that area behind your battery so you can put your receiver on the the chassis and if you do that David Jun setup with the steering you can then move you speedo to the bottom deck as well. That should help with the weight being lower in the car.
IT is a nice looking car. Gotta love that blue aluminum.
Old 10-03-2002, 06:37 PM   #667
Steevo's Avatar
Thanks for the advice wyd. I will do that this weekend....I am thinking of losing some of the plastic cowling over the motor as well so that i might squeeze on a heatsink.... Will post some pics of the mods after i make them for all to see. Am working on a web page for TA03 tips and mods with heaps of pics.....
Old 10-03-2002, 08:17 PM   #668
wyd
Tech Legend
wyd's Avatar
Steevo that is cool. I had 2 different DJ 03's and had both setup like this once I saw a picture of DJ car. For the steering you need to flop you alum. steering arms and move the servo to the other side. I used ShoeGoo to hold the servo once I had everything lined up. Once you move the servo then the speedo will fit beside the servo and and receiver will fit in that area behind then battery once you get that trusty Dremel tool out and open it up some.
It is very trick looking once it is done. I look forward to seeing your car after you do more modifications.
Old 10-04-2002, 08:56 AM   #669
Cube is offline   Reply With Quote
Old 10-05-2002, 12:27 AM   #670
Steevo's Avatar
Cube try www.asiatees.com for some alloys to suit several Tamiya models.
Steevo
Old 10-07-2002, 11:45 AM   #671
fabolousRC's Avatar
Send a message via AIM to fabolousRC Send a message via Yahoo to fabolousRC
Steevo..do you think those GPM alu arms too heavy for the car? I mean I have your double FRP setup too and the car still feels like a tank.
Tamiya DB01 Durga\Kyosho Lazer ZX-5\Kyosho Turbo Optima
Lex Tyler Paints \ Norcal Hobbies \ Bay Area Peninsula R/C Club
fabolousRC is offline   Reply With Quote
Old 10-07-2002, 02:06 PM   #672
Steevo's Avatar
Yeah you're right, the car does still feel like a tank and the FRP chassis does nothing to help this.
The Tub Chassis weighs in at 98.5Gramms and the FRP Kit is around the same. As for the alloy arms they are a few gramms heavier than the plastic parts but they are strong, very strong compared to the plastic. I had 2 of the plastic knuckle arms crack around where the screw holds them in the hub carriers when i had the car set up as standard. There is next to no chance of this happening with the alloy. Also you have to admit that they look soooo cool!!!
Old 10-07-2002, 06:07 PM   #673
One time, I tried the following. I cut the the mounting tabs off the servo then glued (rubber cement) it on a piece of PCB. Then I servo-taped the ESC right next to the servo on one side then the receiver on the other side. I stood the receiver on its side to make the assembly narrower. I then taped the assembly on the chassis. I had to ditch this approach though after just racing this once. The pcb was torn off FRP chassis. Should have glued it in the first place
Now I am using a saddle pack chassis but can't do the same because there are holes on the spot under where the servo mounts to. I might try doing this again but instead of using tape, I might use two screws and an aluminum mounting post as a nut to hold the entire PCB. I won't be able to cut the mounting tabs this time
TRF512 is offline   Reply With Quote
Old 10-09-2002, 10:57 PM   #674
Steevo's Avatar
Default TA03 Alloy Parts
If anyone is interested in some as new Aluminium Hopups for the TA03 or a FRP chassis set visit the FOR SALE section.
Old 10-10-2002, 03:39 AM   #675
Manuel's Avatar
Hey Steevo, where are you in Sydney?
I didnt know there were any ta03 users still around here
Gotta go see this 'for sale' post of yours
Manuel is offline   Reply With Quote
Veteran Tamiya TA02 fan chappi Electric On-Road 88 07-28-2015 07:38 AM
Tamiya TA03 hermanchauw Singapore R/C Racers 16 02-04-2009 05:14 AM
WTB: Tamiya TA03 -Jimmy- R/C Items: Wanted to Buy 1 02-13-2007 01:46 AM
TA03 help! or any tamiya fan! BrainTeased Electric On-Road 5 02-16-2004 01:35 AM
Tamiya TA03 hop-ups Evil_S10 R/C Items: Wanted to Buy 2 11-21-2002 02:13 PM
