Old 09-18-2002, 08:52 PM   #646
Trim some material off of the gear case, try looking rims that are lighter than others. The problem for the 03 is not being faster its how you make the care carry speed in the corners and out. I found that you have to make sure the car has even length shocks all aroung and that there is no binding in the drive tran and lower the car down.
rowdyrj is offline   Reply With Quote
Old 09-22-2002, 12:59 AM   #647
OK, thanks. Then among all three, TA03F, TL01, and FF01, which car is the strongest?
ckh1328 is offline   Reply With Quote
Old 09-22-2002, 11:14 AM   #648
I can not answer that because I don't have no experience with the other cars. The FF is lighter, the TL01 you have to some work to it if you are buying the basic kit.
Old 09-23-2002, 02:42 AM   #649
Steevo's Avatar
My brother has a TL-01 and I have a TA03F. When we first started running them against each other we both had 16Turn Motors which were by Eagle Racing (cheapies) With the same motors and the same pinion gears fitted his car ran consistantly faster than mine in a straight line. I have since read in a recent comparison in a RC Magazine that it is a fact that TL-01's are quick for their comparitive motor sizes due to their drivetrain setup.
See the RADIO CONTROL TOURING CARS MAG "FALL 2002 Edition" for a good comparison on the AcademySTR-4/AssociatedTC3/CEN GX-1/Tamiya TL-01/and the Traxxas 4-TEC. It makes for some good reading...
Steevo is offline   Reply With Quote
Old 09-23-2002, 11:24 AM   #650
psycho's Avatar
Steevo
Keep in mind that cars don't all have the same internal transmission ratio or spurgears. That's probably the difference you're seeing. Even though you are using the same pinion gears, chances are you are not running the same gear ratio in both cars. You would need to run the same gear ratio in both cars for this to be a true test.
psycho is offline   Reply With Quote
Old 09-25-2002, 09:45 AM   #651
Default 6 turn TA03f
Hey Steevo,
Where's the update on the 6 turn rocket tests?
I'm dying to hear how the car responded to all that power....I hope you got a video of the gear boxes spewing parts
crookedlawyer is offline   Reply With Quote
Old 09-25-2002, 03:25 PM   #652
Steevo's Avatar
No Worries mate,
I am just waiting on my 12tooth pinion gear which i have on order before i dare try anything. I have had some overgearing problems on my main car which has kept me more than Busy. I just melted an 11 Turn motor which i had only just bought a few weeks ago by trying to run it too high and without enough break between runs. Oh well you learn from your mistakes. I do have confidence that the car will handle it though as a drag race is very short and my ESC has a speed up function which allows control of acceleration so i can set it so that it comes on gradually rather than all at once.
Old 09-25-2002, 07:06 PM   #653
That's no fun. Your supposed to put a 25 tooth pinion on there and just mash the throttle!!! And get a video of parts flying everywhere
Well I guess your idea will work too but is not quite as entertaining....let us know.
Old 09-25-2002, 07:12 PM   #654
hmmmmm...
I want to see smoking rubber and skid marks
about the flying parts, I dnt think so. Car's too tough for that heheheheh... not unless he uses concrete for an emergency brake (or break)
TRF512 is offline   Reply With Quote
Old 09-28-2002, 06:30 PM   #655
Steevo's Avatar
I think you are right about these things being tough TRF512
Any way the drag version is now in a new stage of development with the car being converted from 4WD to rear wheel drive. It all looks good so far and i am looking forward to seeing how the thing drives. I am not expecting too much in the way of steering but it does only have to hold a straight line. I just wish i was able to upload some video of it when it gets going but i don't have the software to do it......
Old 09-28-2002, 06:37 PM   #656
Pics of it will be more than suitable....
I was kidding about parts flying everywhere though, I have seen this suckers take a licking and keep on ticking....
Old 10-01-2002, 01:30 AM   #657
Steevo's Avatar
Default TA03 Internal Ratio
Hello everyone,
Can someone please tell me the Internal Ratio for the TA03F with the standard black 0.6 Gears. I think that it might be 2.77 but I am not %100.
Old 10-01-2002, 04:22 AM   #658
Yep 2.77. Here's a helpful chart:
Gear Drive Ratios
0.4 PINION:_ 20 21 22 23 24 25 26 27 28 29
SPUR:__ 63_ 63_ 63_ 63_ 63_ 63_ 63_ 63_ 63 63
GEAR RATIO: 7.68 7.31 6.98 6.68 6.40 6.14 5.91 5.69 5.48 5.30
0.6 PINION:_ 14 15 16 17 18 19 20 21 22 23 24 25
SPUR:__ 43 43 43 43 43 43 43 43 43 43 43 43
GEAR RATIO: 8.51 7.94 7.44 7.01 6.62 6.27 5.96 5.67 5.41 5.18 4.96 4.76
Old 10-01-2002, 04:23 AM   #659
Sorry, but I can't get it to line up right here ...if you want a better copy I can email it to you, just ask
Old 10-02-2002, 10:29 PM   #660
Dongskie's Avatar
Trader Rating: 44 (100%+)
Rough512: I'd replace it, if I have one... so far that's all I have.. How's your 03 doing?? haven't seen that on the track lately...
Steveoo: Nice 03!!
Bajer 1/5th
Dongskie is offline   Reply With Quote
Veteran Tamiya TA02 fan chappi Electric On-Road 88 07-28-2015 08:38 AM
Tamiya TA03 hermanchauw Singapore R/C Racers 16 02-04-2009 06:14 AM
WTB: Tamiya TA03 -Jimmy- R/C Items: Wanted to Buy 1 02-13-2007 02:46 AM
TA03 help! or any tamiya fan! BrainTeased Electric On-Road 5 02-16-2004 02:35 AM
Tamiya TA03 hop-ups Evil_S10 R/C Items: Wanted to Buy 2 11-21-2002 03:13 PM
SEO by vBSEO 3.5.0
