Old 03-11-2002, 02:26 PM   #301
psycho's Avatar
I'll try to remember to look when I get home.
psycho is offline   Reply With Quote
Old 03-11-2002, 04:16 PM   #302
Psycho-Are you racing this weekend at Castle?
Dayten is offline   Reply With Quote
Old 03-12-2002, 09:59 AM   #303
psycho's Avatar
Doh! I forgot to look at the internal gear ratio! I'll try to remember tonight.
Dayten
You bet! I'll be racing sportsman stock sedan and F1. We raced at Sheldons last Sat. It's always fun on that tight slippery track.
Old 03-12-2002, 10:03 AM   #304
Psycho-Cool, I'll be entering sportsman stock sedan.
Old 03-12-2002, 10:09 AM   #305
psycho's Avatar
Awesome! If the weather is cool like the predictions say, you'll want to run pretty soft or you'll push like crazy. If the budget allows, I'd pick up a set of Yokomo medium Sprints and Yokomo medium inserts and start off with those. If grip starts coming up in the afternoon, switch to your Shimizus.
Old 03-12-2002, 11:03 AM   #306
psycho-Thanks for the tip on tires. If I don't buy an FM Radio, I'll get the tires. Which sedan are you running, XXX-S? Hope to see you there.
Old 03-12-2002, 11:25 AM   #307
psycho's Avatar
You need the tires more than you need an FM radio. The FM radio won't make you a better driver of get you better laptimes. Don't get me wrong, it's a good thing to have, but if you're out there with the wrong tires, nothing else makes much of a difference. imho.
Yeah, I'm going to race my xxx-s this weekend. Of course, I'll probably wind up in the d-main, but it's all good! I'm out there to have a good time! I just picked up a new race pack, so I should have a little more ponies this week. ha! It should be a fun one.
Old 03-13-2002, 07:39 AM   #308
Psycho-Looks like the weather will be in the 60's-70's this weekend. I took a look at Yokomo's site and they recommend the ZR-138G Beltec 5G medium racing slick for asphalt. Would that work at Castle? How about the inserts? Do you have a model number or part number I can reference? I'll try to pick some up today if they are not sold out.
Old 03-13-2002, 11:21 AM   #309
psycho's Avatar
Dayten
If you are going to buy belted tires, stick with the Shimizu's. They tend to be less affected by temperature changes as the day goes on. I don't have Yokomo's part# for the medium Sprints, but they are clearly marked as such on the package. They are around $8 for two. Cam or anyone there can show you which ones they are.
Old 03-13-2002, 03:43 PM   #310
psycho's Avatar
Dayten
I went by Castle earlier and they had plenty of Yokomo Sprint Mediums in stock. Run, do not walk, though. They are always out of them.
Old 03-13-2002, 03:54 PM   #311
psycho-Yeah I know they sell out pretty quick on race week.
Old 03-13-2002, 05:43 PM   #312
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
I finally get to run my 03R this weekend. The Tamiya race is in like 3 weeks or so. I need to pick up my new parts tommorrow and then put them on and then put the radio gear in it. I will paint the body Thursday night and put the finishing touches on the car Friday night. Good thing is the track is 40 minutes from my house so I can practice from 10am til racing starts at 5:30.
The car is coming together nicely so far. It should work pretty good. A guy ran an 03 last week against the 04's and was plenty fast. He needed some steering but the 03 didn't unload in the corners like the 04's were doing.
Old 03-13-2002, 09:01 PM   #313
psycho's Avatar
wyd
I'm looking through the TA03F David Jun Edition instruction and they don't list the internal gear ratio. They do show what the final gear ratio is for 20-29T pinions, though. This is with the .4 gears.
20T 8:44:1
21T 8.01:1
22T 7.67:1
23T 7.34:1
24T 7.03:1
25T 6.75:1
26T 6.49:1
27T 6.25:1
28T 6.03:1
29T 5.82:1
You could, of course, do a little math and figure out what the internal ratio is from this info. I don't feel like counting the teeth on the spurgear.
Old 03-14-2002, 02:07 AM   #314
Jimmyd's Avatar
Finally got to run my 03RS TRF. I tested the car on asphalt parking lot and slighty rough concrete surface with a few pylons.
I was using tamiya B2 and 50/17 48p spur and pinion.
I found the handling to be excellent on both surfaces. Changes direction quickly yet rear end is not loose. Very predictable feel. Top speed quite fast with the type T 23turn. Overall quite pleased though i cant say how it would do in the race.
Jimmyd is offline   Reply With Quote
Old 03-14-2002, 08:32 PM   #315
wyd
Tech Legend
wyd's Avatar
pyscho thanks for the info. That will help me out alot.
Veteran Tamiya TA02 fan chappi Electric On-Road 88 07-28-2015 07:38 AM
Tamiya TA03 hermanchauw Singapore R/C Racers 16 02-04-2009 05:14 AM
WTB: Tamiya TA03 -Jimmy- R/C Items: Wanted to Buy 1 02-13-2007 01:46 AM
TA03 help! or any tamiya fan! BrainTeased Electric On-Road 5 02-16-2004 01:35 AM
Tamiya TA03 hop-ups Evil_S10 R/C Items: Wanted to Buy 2 11-21-2002 02:13 PM
