Old 08-25-2001, 03:49 AM   #16
zxt
zxt's Avatar
Default actually
mine is not converted to rally but my friend TL-01 is...tho I didnt exactly see his car...its just that TL-01 has a sealed gears so it wont subjected to dirt as much as the TA-03...
now where is Jimmy GT-R?
zxt is offline   Reply With Quote
Old 08-25-2001, 05:54 AM   #17
r32
r32's Avatar
Send a message via ICQ to r32
Jimmy is probably still drifting around the WWW wondering what the heck happened to RCtouring.....................
When he isn't doing that he's probably busy painting big black lines on the road with his GT-R.
r32 is offline   Reply With Quote
Old 08-25-2001, 07:23 AM   #18
jcr
But how to get it to rally spec first? Like the ride height and stuff like that? And what should the ride height be?
I can block of the dust with wheel wells so less dirt will get in
jcr is offline   Reply With Quote
Old 08-26-2001, 02:02 AM   #19
r32
r32's Avatar
Get the ride height as high as you can get without the driveshafts binding! Rallyblock tires would be good for digging into loose surfaces...........
Old 08-26-2001, 04:28 AM   #20
Alvin's Avatar
i think i melted my rally tires today, ran my car @ noon in the sun with those tires
Does the lhs sell replacement rally tires? I mean those which are not tamiya made.
Thanks!
Regards,
Alvin
Alvin is offline   Reply With Quote
Old 08-26-2001, 06:46 AM   #21
r32
r32's Avatar
Tamiya's rally block should be the cheapest rally tires you can find.......they will not last long on abrasive surfaces. Mine only runs on gravel so they're still in fairly good shape........
Old 08-26-2001, 06:54 AM   #22
Alvin's Avatar
drat drat drat. Apart from rally block tires, what other options are good for usage off-road? Buggy tires?
~Alvin
Old 08-26-2001, 08:18 AM   #23
jcr
well how do i know when the ride height is too high to bind the driveshaft?
also by making the ride height higher, do i need longer springs?
Old 08-26-2001, 08:27 AM   #24
r32
r32's Avatar
When you lift the car off the ground if the car cannot move its wheels without causing the drivetrain to skip as a result of the driveshafts drooping too much (check for steering too) then it's too much. Use buggy front shocks, or use shocks with longer shafts and bodies.
Old 08-26-2001, 10:22 AM   #25
jcr
how about one inch off the ground? do you think that would be enough?
still don't really get the drivetrain to skip part.
Old 08-26-2001, 08:08 PM   #26
r32
r32's Avatar
One inch should be sufficient.
Old 08-27-2001, 01:28 AM   #27
erap's Avatar
Send a message via ICQ to erap
hi guys, seems most of you are into rally now. i'm also planning to convert my ta-03f pro to a rally car. i'm basically using my hpi pro 2 for racing around parking lots now, hehehehe
erap is offline   Reply With Quote
Old 08-27-2001, 08:13 AM   #28
jcr
hmm.. i guess it's not going to be one inch using the original shocks. it's like 15mm. It's only the front that makes it low but i think 15mm might be high enough?
Old 08-29-2001, 06:58 AM   #29
r32
r32's Avatar
Well I dunno, I got my TB-01 for rally duties so I don't convert my 03s for rally. I suppose you'll have to be picky about your rally terrain if you can't get more travel...........
Old 08-29-2001, 07:16 AM   #30
jcr
also anyone tried making a chassis to fit saddle packs or have a chassis that fits it?
Veteran Tamiya TA02 fan chappi Electric On-Road 88 07-28-2015 07:38 AM
Tamiya TA03 hermanchauw Singapore R/C Racers 16 02-04-2009 05:14 AM
WTB: Tamiya TA03 -Jimmy- R/C Items: Wanted to Buy 1 02-13-2007 01:46 AM
TA03 help! or any tamiya fan! BrainTeased Electric On-Road 5 02-16-2004 01:35 AM
Tamiya TA03 hop-ups Evil_S10 R/C Items: Wanted to Buy 2 11-21-2002 02:13 PM
