Old 02-16-2002, 06:44 AM   #256
Regional Moderator
Send a message via AIM to Mike F
what about the slop up front, any suggestion on how to reduce that?
Mike F is offline   Reply With Quote
Old 02-16-2002, 09:32 AM   #257
psycho's Avatar
Mike F
A trick that I've used on other cars, but not on my TA03, is to put a rubberband over the bellcranks. It squeezes them together and eliminates the slop in the bellcranks without adding additional risk of damage.
psycho is offline   Reply With Quote
Old 02-16-2002, 09:38 AM   #258
Regional Moderator
I'll try that, thanks
Old 02-17-2002, 05:06 AM   #259
Fit
Mike F,
I bought a GPM torque rod set and used it on the front
to remove most of the suspension slop.
If you can still find it try it. It works quite well.
Any good websites for the 03?
Kerchie's website is no longer available, that was
one of the best 03 sites I've come across so far.
Fit is offline   Reply With Quote
Old 02-17-2002, 05:37 PM   #260
Regional Moderator
Default ttt
thanks
Old 02-17-2002, 08:46 PM   #261
There is not much you can do as far as slop goes on the TA03. I have 3 cars and all of them has some slop to them. But if you are able to find the GPM torque rod set that Fit suggested it removes a lot of the slop.
What brand and type of bodies do you guys use. I will be using it at club races so it doesn't have to be tamiya bodies. Does the HPI bodies wheel cut outs line up well with the TA03 chassis?
Just rebuild my TA03R-TRF, but won't be racing it, just for display. I'll be running my Pro for club races. I just can't bare to see the carbon fiber on the TRF getting all scratched up.
Dayten is offline   Reply With Quote
Old 02-18-2002, 09:43 AM   #262
psycho's Avatar
The only bodies that will have all the markings line up will be Tamiya bodies. I am running a Losi Stratus-phere body on my TA03 and the wheel well cutouts lined up perfectly. I had to mark for the body posts myself. The only thing to watch out for when marking the body post holes is the fact that the rear body posts have a tendancy to point slightly toward the front of the car. If you mark at the center of the rear posts, the body will sit too far back when you mount it. You might want to cut the body posts down a bit before marking. I don't really like HPI bodies because they are very thin and crack at the front wheel well easily. On the other hand, they have the best decals (of the non-Tamiya bodies.)
Old 02-18-2002, 03:22 PM   #263
Fire's Avatar
speaking of bodies i have a hard time fitting bodies onto my 03
the rear body posts are too high, not enough holes down at the bottom of the post, is there some kinda easy fix that can fix this problem?
Fire is offline   Reply With Quote
Old 02-18-2002, 04:27 PM   #264
psycho-Thanks for the tip regarding the Losi body.
fire-I had the same problem. If you are able to find them, I use the Cross TA03 body mounts. The rear body post have holes that go further down then the original Tamiya body post.
Old 02-18-2002, 05:12 PM   #265
psycho's Avatar
I'd just drill an extra hole or two further down.
Fire, try www.castlehobbies.com for the Cross body posts. I'm pretty sure they have a set or two on their clearance wall. You'll probably have to call them, though.
So, Dayten, are you racing at Castle this weekend? I hope it doesn't rain again! I can't wait to get out there!
Old 02-18-2002, 05:22 PM   #266
Fire's Avatar
i just used a drill with a 1/16 bit to drill 2 more holes on each of the rear body post and now i can fit my stratus on~~
Old 02-19-2002, 07:50 AM   #267
Psycho-I'll try to make it out if I get my body mounted and painted, my shocks rebuilt and my tires glued in time. Then try to setup my car. If you see a guy out there with an uncontrollable car out on the track that's me. lol.
Old 02-19-2002, 09:53 AM   #268
psycho's Avatar
Dayten
Don't worry! There will be plenty of guys with uncontrollable cars out there! What tires are you running?
Old 02-19-2002, 09:09 PM   #269
Psycho-I was chatting with Cameron and he suggested Pit Shimizu D27R belted slicks with Yokomo ZR-037F firm inserts. He also suggested using 80wt oil, but he didn't recall if i should use 2 hole or 1 hole pistons.
I am going to try this setup that I picked up from xtremerc for smooth track setup for the TA03.
Rear
80wt oil
Blue Springs
1 hole pistons
2 degrees of camber
4mm ride height
battery to the rear
Red sway bars
16 tooth pulley
Front
80wt oil
Blue Springs
1 hole pistons
2 degrees of camber
yellow sway bars
16 tooth pulley
Stock Hub Carrier
Old 02-20-2002, 02:34 PM   #270
psycho's Avatar
Dayten
I agree on that choice of tire, but I think the firm insert may be a bit too firm. If the budget allows, I'd also pick up another set and put medium inserts in them. This way you can go medium all around or medium rear and firm up front depending on how the car behaves. I find the car comes around a lot with the blue springs in back, so I run Associated silver springs in the rear. Bring a sharpie pen so you can mark your tires and set the camber for the track. You might need to go with a little more camber in the rear, but you won't know unless you mark your tires and check the wear. I would also try to wear in your tires a bit before coming out. With the rain, the old coat of vht has washed away, so it might be a little slicker than normal. If it starts getting warm in the afternoon, you'll be happy you have the 27's. Are you only going to run sedan? I'll be running sedan and F1. If you have an F1 car, bring it! That class is awesome!
Veteran Tamiya TA02 fan chappi Electric On-Road 88 07-28-2015 07:38 AM
Tamiya TA03 hermanchauw Singapore R/C Racers 16 02-04-2009 05:14 AM
WTB: Tamiya TA03 -Jimmy- R/C Items: Wanted to Buy 1 02-13-2007 01:46 AM
TA03 help! or any tamiya fan! BrainTeased Electric On-Road 5 02-16-2004 01:35 AM
Tamiya TA03 hop-ups Evil_S10 R/C Items: Wanted to Buy 2 11-21-2002 02:13 PM
