Old 10-18-2001, 01:19 AM   #136
zxt
zxt's Avatar
Default How big the diiference bet the 2?
Also I have sway bars, full ball bearings, aluminum motor mounts...how does my 03 compare to a DJ? Does the carbon chassis, aluminum shocks and narrow belt does a lot?
thanks...
zxt is offline   Reply With Quote
Old 10-18-2001, 03:58 AM   #137
Only thing that I see that you would need is the narrow belt and belt tensioner and you can race it like that. I would install a torque-splitter when you get a chance. I run two torque-splitter one in the front and rear. This is similair to what what other top racer are running but one disadvantage is that you do not have rear brakes I would advise anyone to only run this set-up on a fast track.
rowdyrj is offline   Reply With Quote
Old 10-18-2001, 07:42 AM   #138
zxt
zxt's Avatar
Default Huh?
Hows that? I know if u install torque splitter aka oneways in front then you wont have break in front...what if you install front and rear? You'll just lose the break in rear? and have breaks in front? but you also have one ways in front right? Hows that?
also I forget to tell you that I have oneways in front and abelt tensioner too...isn't the belt tensioner stock?
whats the use of narrow belt anyways? less friction?
Thanks again...
Old 10-18-2001, 07:57 AM   #139
With a one-way in the front and rear you will not have brakes at all. You are correct the narrow belt helps to reduce friction.
Old 10-18-2001, 08:51 AM   #140
I've got a RS with full bearings, torque splitter, but tub chassis. How much better a car will a DJ be if I were to convert my RS into a 03F by changing the chassis to a 03F tub chassis and using the narrow belt? How will the cars performance be affected with th use of a carbon chassis and a tub chassis?
Wouldn't I not save a bundle if I were to get the plastic tub, narrow belt, gears, (shocks.. I've got those alloy ones already)? What sort of performance advantage will I gain? I know that that DJ comes with alot of light weight stuff, do they help make the car faster?
Ivan is offline   Reply With Quote
Old 10-18-2001, 10:46 AM   #141
I have never raced the 03 RS version. Its the shorter version of the 03 corrected. I did race the 02SW and that car turn in quicker but you are limited to one type of body. I would leave the RS alone and just practice your race set-up. If you race on a lot of tracks with short straights this is the car to have.
Old 10-18-2001, 08:55 PM   #142
I've not race much with the RS. Only recently I've converted my FS to a RS just for the fun of it. Since, it's shorter, it does turn in quicker. However, competing with those larger wheelbase cars like the F, it was a tad slower. Also, the lack of short wheel base body shells to quite annoying. I think I'll try bodies with hatchback soon. How do I make up for the lack of speed?
What's the difference between a 24mm wheel and 26mm wheel? If I go with a 26mm wheel, won't I make up for the lack of speed, but reduce in acceleration?
Old 10-18-2001, 10:44 PM   #143
Fire's Avatar
24mm is norrower than 26 mm therefore lighter and less friction, they are all the same radius therefore max speed will not change much but acceleration should be a tad slower with 26mm setup.
Fire is offline   Reply With Quote
Old 10-19-2001, 05:42 PM   #144
Why then do ppl use 26mm? More traction?
Old 10-20-2001, 07:21 AM   #145
Manuel's Avatar
lets see if this works...
Manuel is offline   Reply With Quote
Old 10-20-2001, 07:49 AM   #146
Fire's Avatar
ppl rarely use 26mm for electric touring in the recent years, mostly nitro guys use them, nitro cars are heavier and the race is longer therefore need more tires, also added traction won't slow them down because they have plenty of torque. too much traction for electric will scrub off speed and waste the power.
Old 10-20-2001, 09:00 AM   #147
zxt
zxt's Avatar
Default nice wheels manuel
where did u get those?
Also is that a regular 03 with carbon chassis or was that a 03DJ?
Old 10-20-2001, 12:36 PM   #148
porkybmx's Avatar
Send a message via AIM to porkybmx
Hey ZXT, they are Integy wheels. I have the same ones on my ta03rTRF. Mine are white. Here:
porkybmx is offline   Reply With Quote
Old 10-20-2001, 04:32 PM   #149
Manuel's Avatar
The chrome ones are packaged as Laser rims, we get them over here with Eagle tyres and inserts, A$30 for a pair
Oh ye, and its a regular 03f with:
frp chassis
ball bearings
tamiya swaybars
aluminium counter shafts
reinforced drive belt
lightweight drive shafts
fantom 11x3; or atlas 23xsomething(hehe)
motor heatsink
cross hub carriers
cross front gearbox supports
cross cf damper stays (not in pic)
custom aluminium servo mounts
esc is a MTroniks DigiSprint with custom heatsink (which cost $1 as opposed to $25 for a hobby shop one)
there must be more i've left out, I know it would have been cheaper to get the pro or the DJ but this way its been more fun, and im only a basher...
Old 10-23-2001, 07:48 PM   #150
Does anyone have any experience with the RS? How does it compare with the F and R versions? Is it worth getting the RS FRP chassis, or should I just stick with my tub chassis?
Veteran Tamiya TA02 fan chappi Electric On-Road 88 07-28-2015 07:38 AM
Tamiya TA03 hermanchauw Singapore R/C Racers 16 02-04-2009 05:14 AM
WTB: Tamiya TA03 -Jimmy- R/C Items: Wanted to Buy 1 02-13-2007 01:46 AM
TA03 help! or any tamiya fan! BrainTeased Electric On-Road 5 02-16-2004 01:35 AM
Tamiya TA03 hop-ups Evil_S10 R/C Items: Wanted to Buy 2 11-21-2002 02:13 PM
