Like Tree3Likes
Tamiya TRF415
Old 03-19-2006, 01:13 PM
  #13396
JRRobiso's Avatar
Exclamation 415MSX Ball Studs used @ TITC 2006
Question!
Who makes the light blue alum ball studs used on Satoshi & Mark R.'s MSX's bulkheads @ the TITC 06 races? It was also used on the new steering assembly as well. (click on link below)
TITC06 415MSX
JRRobiso is offline
Old 03-19-2006, 01:16 PM
  #13397
JRRobiso's Avatar
Actual pic of link:
JRRobiso is offline
Old 03-19-2006, 02:00 PM
  #13398
stuey's Avatar
Originally Posted by Jack2
Quite right, they are 35t not 32t , Must be going mad.......
I still thinks its worth while running the TA05 pulleys because its a better internal ratio to work with (well for Modified anyway) and I think the TA05 pulleys are better, you don't have to do any gluing and I think they are made from a better material.
does any body know what the ineternal ratio is on an 415ms/msx with the ta05 front and rear diff pulleys and center pully.
stuey is offline
Old 03-19-2006, 02:06 PM
  #13399
Same as TA05, 36/16 = 2.25
Mr_Orange is offline
Old 03-19-2006, 02:10 PM
  #13400
Burlap's Avatar
Mmmm, broken tables. Can you thumbnail that dude?
Burlap is offline
Old 03-19-2006, 02:40 PM
  #13401
TRF415boy's Avatar
Originally Posted by Andrew Twigger
Hi guys,
Can anyone recommend a combination of ball ends and ball studs that I can use which will give my joints a little more resilience against popping off so often? The standard ones are pretty bad and I've now run out of Tamiya ones to replace them with. I bought some RPM ball ends, but only discovered that the Tamiya ball studs have larger balls once I fitted up a new turnbuckle with new ends....how annoying!
Any ideas? Suggestions from UK users would be most useful, as an order from the likes of Champ etc can be quite expensive once I get going!
Andrew
Err they're not as bad as you seem to say i hardly ever have them pop off and only on big crashes.
TRF415boy is offline
Old 03-19-2006, 02:43 PM
  #13402
TRF415boy's Avatar
Originally Posted by Sushi Man
oh WOW.. tamiya does stupid things... the i didnt know that the blue/white springs werent even a pound off....
No they're not tamiya white have been measured at 15.27lbs that 14.8 value is just wrong.
Old 03-19-2006, 02:44 PM
  #13403
TRF415boy's Avatar
Originally Posted by JRRobiso
Question!
TITC06 415MSX
It could be them new ball nuts that came out earlier this year from tamiya.
Old 03-19-2006, 03:05 PM
  #13404
JimmyMac's Avatar
Originally Posted by Charles Godwin
Anyone know if another manufacture makes 0* castor blocks, can't seem to find any that tamiya makes because i need some more steering but, does the HPI supsension give you more steering and if so what are the parts that i need
Cheers, Charles
Xenon makes 0 degree castor blocks for the 415/EvoIV. Xenon also makes better 0 degree rear hubs for the 415/EvoIV suspension as well. I have both. but have yet to try them out since asphalt season has not started yet here.
JimmyMac is offline
Old 03-19-2006, 03:31 PM
  #13405
stuey's Avatar
can anybody tell me were i can download the 415 msx instruction manual and part list
stuey is offline
Old 03-19-2006, 04:03 PM
  #13406
Default 415ms basic spares list?
G'day guy's
I have only just started racing a 415MS, what would you guys recomend as basic spares to have in my pit box.
PRO 2 RACER is offline
Old 03-19-2006, 04:23 PM
  #13407
Burlap's Avatar
Originally Posted by PRO 2 RACER
G'day guy's
Lower arms, front uprights, C-Hubs and belts. Those are the only spares I have (maybe also worth getting some spare flange tubing, which goes bottom screw on the front upright).
Burlap is offline
Old 03-19-2006, 04:42 PM
  #13408
the whole bushing set and the bushing that goes in the toe plates.
XingXing is offline
Old 03-19-2006, 05:08 PM
  #13409
Trader Rating: 42 (100%+)
Default MSX on foams..
Looks like Tamiya had a pretty good day at Carpet Nats.
Jimmy Jacobson BQ'd Mod foam....from listening to the live feed it sounded like R.Burch punted him big time in the first few laps.
Josh Numan also made the B.
Hopefully one of both of them can share their setups.
Nexus is offline
Old 03-19-2006, 05:35 PM
  #13410
Sushi Man's Avatar
hey does anyone know if the TA05 sway bar kit will fit/work with the 415?
and does anyone know the partnumber to the little black peaces that hold the sway bars in (4)
Sushi Man is offline
