Tamiya TRF415
#1306
Regional Moderator
Originally posted by Al75
Here is the new version of the Tech Racing MY02
http://www.tech-racing.co.jp/my02m.htm
Is that reminding me something ???
By the way it is much cheaper than a 415.
NOT to be rude but if you look a page or 2 back you will see this has been posted about 3 times or more now and its a conversion kit for the tech car for people that has already have the car ! NOT a full kit
#1307
Re: Belt ???
Originally posted by LeoChan
My 415 use 12T motor play about 30packs battery ,
the Front belt will too long .
Have u tried retensioning the belt?
#1308
Well I broke the first thing on my 415 today. A front body post. hehe.. It was a low speed hit dead into a metal corner dot that was sticking up. The post was cut clean in half where the lower body pin holds down the foam bumper. Oh well, I have new ones...
Anyways, just been playing with setups and I finaly think I have my 415 handling as good as my Yok SD. More testing and tuning needs to be done though.
Question for you guys. On the setup sheets, they would call for like 2mm rebound stroke. Or 2.5mm... or 3mm. Anyways, I've always wondered how they came up with this measurement since it's not measure like droop? After reading the instruction booklet over and actually reading the small tuning guide... I was wondering... do they measure it by measuring how far the droop screw protrudes down from the arm? Like the stock setups calls for 1.5mm front and 3mm rear. So on say.. Surikarns setup.. it would be 2mm front and rear that the screw would be protruding underneath the arm?
Well let me go clean off the car and replace the body post....
#1309
Just in case this is hard to follow, lets say you have a ride height of 5mm eith everything in your car. You pull up on the shock tower (or lift the car with a hobby knife) untill the tires start to lift off the ground. Now it's at 8mm, so you subtract 5 from 8 and you get 3mm. And that is your rebound stroke. This is the way Difuser told me how to do it, and thats how I measure droop/or suspension travel ever since.
-Sushi Boy
#1310
That's how I thought they did it before. Measure ride height. Then keep sliding the ride height gauge under til the tires lift up. Then subtract. But, I'm not sure now after reading the Manual. I'd just like a "true" clarification on the exact way they do it for the setups. So I dunno...
#1312
here's a somewhat related question. when you keep pushing the ride height gauge, and the wheels start to come up....
how do you fix it if one of the tires come up first? i know this means the chassis is tweaked. and you need to play around with the shock collars and the tension on the springs, but how do you do it?
sorry rod, i know you showed me last time but i forgot. thanks for the help ahead of time.
race report: my 415 finished 1st in the B-main at the OC Circuit race this sunday. VERY HAPPY WITH THE CAR
#1315
Yes have this belt
my car total play 40packs battery but used 2 Front belts.
about few pack will change F belt .
#1316
Originally posted by D_Ames
So is everyone abandoning the EVO III now that this car is out??
#1317
Yes have this belt
Yes have this belt
Are they just stretching or are they breaking in the end??
#1318
Also on the tamiya setup sheets when you see the part about C1 and C2 front steering blocks does it mean right and left when you look at the front of the car or right and left from the back of the car looking forwards? Rick
#1319
#1320
Now used 2 belts coming next belt.
easy to long !
my friend use 23T motor same about 50pack battery will too long !
can't use !
easy to long !
can't use !
