Tamiya TRF415
#1261
Originally posted by jeffreylin
Ishiimokei TRF415 = 33500 yen. Shipping is about 8000 yen by EMS.
Do you have a website for these guys??
What are they like to deal with??
#1262
Originally posted by rccarracer
Thats unbelieveable!!
Thats like 25000yen below retail...
#1263
#1264
#1265
Originally posted by Hebiki
ko.. YGPM back
i know this was brought up awhile back. but anyone know whats up with the white belt that surikarn used in his 415?
ko.. YGPM back
#1266
Originally posted by Pyramid
He never use a white belt.. I think that`s the Japanese Team driver car.
#1267
Originally posted by johnny55
Thinking of getting this car in about 2 or 3 weeks from now. If speedtech runs out how can I get this kit from Japan? Thanks.
#1269
Front Diff and Fixed Cener Pully
Well I heard from Tamiya Japan that they currently don't have any plans to make a front diff or fixed center pully for the 415.
As I mentioned in an earlier post, I was able to use the HPI pro2 female outdrives to make a front diff. You will need to move the ridge that holds the bearing in place closer to the pully by about 3.75mm on both sides.
A buddy of mine has been able to make a center pully from the TA04 fixed double center pully. It is too wide but, by shaving some material you can make it fit. You will need to make the actual pully's more narrow along with some other work. I will try it likely on Sunday to see how it works. It is a 15 tooth pully versus the 16 tooth pully that comes with the 415, so the gearing changes slightly. We still need to verify if the grove spacing and height on the TA04 pully will match the belts for the 415.
I hope this helps those foam tire carpet types....
#1271
Regional Moderator
Here is a few pics of the MY02R im running
#1272
Regional Moderator
Front
#1273
Regional Moderator
Rear.............how much different is it to the 415???
#1274
awesome.
thanks ko racer. i really do like the long arms on the my02.
#1275
In case you are interested, attached is the Champs setting used for the recent TITC.
PS: Bottom memo is: He do not use original configuration for rear toe block.. so just refer to the rear mount.
I do not know how it handle as I still have no time building the kit.
