Tamiya TRF415
Originally Posted by Rick Draper
Here goes:
From the hole furthest forward on the motor mount measure towards the cells 16mm then towards the front of the chassis 28.5mm. The diagonal measurement between the original motor mount hole and the new hole you are going to drill is 24.5mm.
Hey thanks for the help mate, does that looks good to you ?
ANybody see the pics of the new xray T2? Look shockingly similar to the msx
looks a downgraded MSX to me, no alloy rear hubs, plastic shocks, etc... Is that the TA06 then ?
the first T1 used the same layout as the 414M, then the FK05 was like the 415/MS.... now the FK06 looks like the 415msx!
hmm, a pattern perhaps??
don't think that's composite carbon material on the suspension parts
Originally Posted by dodo
doesn't look right without the blue blings... then again xray doesn't do blue.... put it together... it will never looked right to my eyes hahaha
Hey guys, does this look like a new rear hub from Tamiya?
http://team-td.net/teamtd/2005exp/ms/ms08m.gif
BTW, this is Satoshi Maezumi's car.
Not like tamiya's is any worse or anything. I can't seem to bend nor break the plastic. Darn tie-rod or kingpin gives before anything. maybe they should market it as "spring plastic" - stronger than metal!
I wonder if any of those T2 parts will fit this ol 415. Would be easier since they will be in stock locally.
I can confirm that it is a 'RC-Square' Option Hub.
Nothing really new, just copied and they still keep some bad design from the old car.
A MSX or Cyclone is a different animal in my opinion.
its the hudy fk06 msx-ray
But my parts situation's quite the contrary to yours.....Tamiya parts are silly-easy to get here in California compared to Xray, which is most likely why I'll be sticking with Tamiya
I got it, the 16mm is the vertical distance... Well I figured that out since it's on the centreline At least I have confirmation since it concurrs with what i have. But the second measurement can't be 28.5mm then, must be 18.5mm since if I put 28.5 I end up with the hole next to the third cell and a diagonal measurement of 32mm...
Right the measurement front to back is 20.5mm or around that. Dunno where 28.5mm came from.
Here are some pics of my MSX. I will get some better ones in good light tomorrow.
Also Xray are good at cloaning winning kits now, pitty they never win anything with them as the competition is always one step ahead
Buyer Beware
