Tamiya TRF415
Can any MSX owner confirm which suspension blocks come with the kit?? i've hear there are only 4 and no spare?? and only 1 set of sway bar too??
1 set of sway bar, yellow(F) and red (R)
- 1 x 1A
- 2 x 1B
- 1 x 1XB
- 1 x 1XD
Originally Posted by alana07
- a yellow front sway bar, a red rear sway bar
- 1 x 1A
- 2 x 1B
- 1 x 1XB
- 1 x 1XD
- 1 x 1A
- 2 x 1B
- 1 x 1XB
- 1 x 1XD
Looks like I need to get some toe blocks as well.
At last my MSX refined has shown up
Buyer Beware
Originally Posted by RayWarner
Any idea what the part numbers for the new outdrives and hub carrier are?
diff joints (outdrives) - 9804249
Originally Posted by dodo
rear uprights - 53807
Now the part number of the blades would be more useful...
Originally Posted by TRF415boy
Err the rear uprights are not new at all, they're the 0° ones that came with the Ms worlds champion set, and they have been available ever since.
Originally Posted by HELLOkitty
and i know you will show us detalied pics...thanks ,kitty
I think these are the blades. Maybe the Corally blades are working also.
New MSX Refine 2 Parts
From what I've noticed so far there are not alot of new parts that the Refine 2 has. New bottom plate w/ extra hole for the rear bulkhead stiffner, rear bulkhead stiffner, adjustable alum diff assembly w/blades & blue alum 3x10 mm tie rods for stabilizer posts. The other new tid bits not mentioned above does not have that much of an impact on the performance on the kit in regards to handling. I think the major must have part is the alum rear bulkhead stiffner for those who plan to keep their 415 MSX converted versions. It would be nice for me though to have a new RC kit to build again. I just can't come to the point of shelling out $440 ++. For those who've decided to get the Refine 2 kit, I envy you. It's a blast to build Tamiya kits & run them afterwards.
I'll probably wait next year for the stores in Asia to carry the new bottom plate & alum rear bulkhead stiffner & also purchase the 3x10 mm tie rods. The new rear diff, still thinking if I should get it.
List of some of the new/option parts with the 415 MSX:
Gold hinge pins,
Steel outer hinge pins,
Fluorine king pins,
Gold shock shafts,
Knurled shock tops and bottoms,
Alloy rear hubs,
Crush spacers for between bearings,
Roll bar stops,
Gold shielded wheel bearings (new item possibly?),
New chassis with hole under motor and screw hole for centre brace,
5mm wheel hex's.
That is it off the top of my head.
Gold hinge pins,
Fluorine king pins,
Gold shock shafts,
Alloy rear hubs,
Roll bar stops,
5mm wheel hex's.
Gold hinge pins,
Fluorine king pins,
Gold shock shafts,
Alloy rear hubs,
Roll bar stops,
5mm wheel hex's.
Gold hinge pins,
Fluorine king pins,
Gold shock shafts,
Alloy rear hubs,
Roll bar stops,
5mm wheel hex's.
Rick, would you take that new hole's position on the chassis for me mate ? Have a look at last page for the dimension i'm looking for. That'd be great !
Thx
fab
