Tamiya TRF415
The only place I've seen it is at the RC Mushroom site, which is in HK.
I'll check out the cyclone ones. Dang I just missed their free shipping deal. Thanks.
Originally Posted by Blue Sky
Hi Ed,
You have mentioned the following part for using the Pro4 knuckles. Is this a European/Asian part since in US I've only seen the MIP CVD ones. And the part number is nowhere to be found. Can you (or someone in the US) point me to the right direction? Thanks.
HP75187 PRO4 Universal axles (NOT the MIP CVD ones)
Any shops in the US getting the 415 refine kits end of this month? Would also want to find out the price if its similar to 40000 Yen.
www.rczone.net has posted some new information about trf415 refine2. Releasedate in japan is dec 10.
about trf415 parts compatibility.
hiya folks!
i have a spare 415 chassis ( the original one).
is it possible to mount the MSX conversion kit on it? or do i need to get the LE chassis?
i already have reversible arms on my current car.
if anyone can shed any light on this, i would really appreciate it.
thanks.
-alexander
thanks.
-alexander
Tryhard:I have been having trouble trying to download the charts for spring rates and 415 toein blocks. Can you help??
Also do you have any info for the TA05 on your web site as well??
Try these instead
Universal Spring Chart
Toe-in Blocks
I don't have any info on the TA05 I'm afriad, although from what I understand, it's probably not far off a 415 fitted with the older suspension.
BTW guys and gals, the new setup section is up, hopefully it'll make it easier to find a setup you want. I do have a load of setups to add (Martin Crisp's IIC's, TRF415boy's, and some guy named Dave Spashet...), that next on the agenda. Again, if anyone has anything to contribute to the site, just send me an email or pm me
HiH
Ed
EDIT - Fixed the excel document link prob on the site, should all work fine and dandy now... cheers for pointing it out.
Originally Posted by foampervert
hiya folks!
thanks.
-alexander
thanks.
-alexander
HiH
Ed
hiya folks!
thanks.
-alexander
thanks.
-alexander
TRADE
hi , woould you trade my vintage team losi xx-cr for something? email back to [email protected] asap as this car is veeeery rare and will change hands faaaast
well, just mucking around as usual
hiya GT racer and other folk,
well, i fugured since i have an EXtra chassis, i might as well build up a new car with teh MSX kit. btw, thanks to all for info!
i'd lurve to cum back again soon.
oh well, seeya around!
happy looting!
-alexander
happy looting!
-alexander
Originally Posted by TryHard
Yup, perfectly possible. All the bulkhead mounting holes are in the same place, so there will be no trouble fitting the conversion... hell you could do as Marc R did (and some on here do) and run it with the old suspension
HiH
Ed
HiH
Ed
I´m not Marc R but I also run the 3mm chassis and the old suspension with the MSX kit.
Using the thicker chassis maybe there also is less chance of tweaking. At least I didn´t have until now.
This is my 415MSX or maybe better said 415X as I´m not using a MS chassis or supension.
Some things were changed since this picture but I have no newer one.
Can anybody tell me what the inner diameter of the diff outdrive bearings is?
diff bearings should be 10mm inside, 15mm out....
Awesome...thank you, sir
