Tamiya TRF415
I think the best screws I ever bought was the ones from Square. They are shinny chrome steel. The 415 is light in weight anyway. I'll have to pick up some more when I go to Hong Kong in a couple of weeks.
I have just got back from running My MSX - Very impressed so far. It is a bit more stable at Mod Speed, turns better and is quite a bit quicker in corners. My lap times are better also.
And the fact you can have the rear diff out in basically second's is just darn brilliant !
IT ARRIVED!!!!!!!!!!!!!!! (The MSX Kit that is)
The nice people from ETamiya sent it out UPS and I didnt get done for any import tax hurrah
Now the decision is if to revert to standard suspension for first run or try the MSX + DJ PRO ....
Oh the decisions...
Oh the decisions...
I bought a Square Ti screw kit for my EVO3. Very good quality and strong. But a good screwdriver is a must anyway. Like the Hudy or LRP.
The aluminium screws may look cool but I donīt want the risk breaking them. Especially when used in some expensive aluminium parts like bulkheads.
Oh the decisions...
Oh the decisions...
Now I also have a 415 MSX conversion on the way.
But itīs really not easy getting one. Most shops are sold out.
My LHS still have some boxes left. Those who are still looking for it
can try emailing the shop owner. [email protected]
got mine, it looks awsome, however, i wish they made a kit for peole who have the ms, and not a 415 with lwt suspension. the damper stays and steering piece was un necasary along with half the hardware, lose the t-shirt and they could have sold the kit for about $150.
lightweight suspension
has anyone encountered problems installing their lightweight suspension on their regular 415?
i can't get the holes on the rear block to line up with the chassis. the instructions ask for spacers to be put under the rear block. but i wish to have it sit flat on the chassis.
front rear block /3mm spacer/2mm spacer/suspension arm/3mm spacer/rear block.
Thanks in advance
Thanks in advance
Those guys interested in purchasing screws cheap...Check out mcmastercarr.com This place has everything...ball bearings, screws, tools, shims, nuts etc...
I've been buying from them for years...I always purchase stainless steel screws for all my cars. They look great and you can purchase 100 screws between $5-$8, depends on the size of the screws.
Like someone posted earlier, I also do not use alum screws in alum bulkheads. Similar type metals will bind over time. Dis-similar(sp) metals will never bind. Be care.
Also, check out the APEC-5 bearings. I've found them to be far superior to anything available to the R/C market. Unfortunaltly they are not sized for 1/8th scales. Little speed secret for ya....
My MSX has just shipped from Speedtech, thanks Steve for the support. Can't wait until next week.
The new ones are different, as the mounting points for the the towers on to the bulkheads has been raised, necessarly because of the quick access bulkheads.
Still not sure on the difference of the steering plates though... if any.
Personally, I quite like my t-shirt... very comfy
Regards
Ed
Thanks in advance
Thanks in advance
Hope this helps.
A new shirt huh. Mine has a piece of bubble wrap. It might make it around my arm!
