Tamiya TRF415
#9766
Originally Posted by odawg315
wow, i run a tight track as well, but i run 7.8 - 8.1 with a stock motor.
#9767
Registered User
A monster stock will be geared very similarly to a mild modified motor. I know at my track, most of the stock guys use monster stocks because they seem to be the best all around stock motor available. Most of us have found the motor performs well at very large tracks 150 x 100 and very small tracks 65 x 35. Keep in mind that they're a little more picky, gearing wise, than a p2k.
I know on our small indoor carpet track 75 x 40 we run 7.7 - 8.2 gearing with monster stocks depending on the layout. For very large tracks, 130 x 60 the gearing is closer to 6ish to low 7s.
#9768
Ceramics
What ceramics is everyone running? As the 415 msx is almost here i am about to start collecting parts for a new car build
#9769
#9770
Originally Posted by Carl Giordano
Almost.....do you know something we need to know....picked up ceramincs from speedtech a long time ago...think they were by yokomo
#9771
ha guys from the USA team that went to the Tamiya Worlds last year do you guys have the setups of the winners GT2 and winners GT1 cars?
#9772
415 front diff. Does it go together like the rear one? With a mix of yokomo parts added?
#9773
I have (or will soon) a 415 and will be running it in an area where no one stocks spares...soooooo...what should i order to make sure I am covered.
Specifics would help me as I dont actually have it yet.
I understand the front and rear shock towers ( I will get the MS)
What else? I will be running the front one way on ashphalt and the yokomo diff on carpet.
Thanks guys
Thanks guys
#9774
I did a search....sorry.
So what exactly are the front uprights?
#9775
Try http://www.acerracing.com/ they have whole car kits for $99.00
#9776
#9777
http://www.tamiyausa.com/articles/fe...cle-id=79#tips
#9778
DJ SUSPENSION
guys, is the DJ Suspension for the 415 a limited edition? cant seem to find it even with Steve ( SPEEDTECH RC) website
#9779
http://home.comcast.net/~anthony.isl...frontdiff.html
front and rear arms
chub set
front knuckles
rear hubs
and maybe these...Tamiya caster block king pins and lower flanged tube set.
Sometimes those little flanged tubes fall out/strip and it would suck not to have one extra. Not sure why you want to buy extra shock towers.
#9780
At the very least...
front and rear arms
chub set
front knuckles
rear hubs
Sometimes those little flanged tubes fall out/strip and it would suck not to have one extra. Not sure why you want to buy extra shock towers.[/QUOTE]
Thanks very much.
Does anyone know why precision rc will only let me buy 1 pair of suspension arms??
front and rear arms
chub set
front knuckles
rear hubs
Thanks very much.
