Tamiya TRF415
#9362
Do you know when it will be released and will it be released in USA and Japan or just USA.
#9364
Yap... Its a global thingy...As heard from my local distributor,its coming SOON !!! And its quite $$$$ !!! Think its about US$200.About there.
#9365
Thanks guy's I new the DJ rear end was released in USA but wasn't sure about conversion kit. I was going to get a new chassis but I might wait till the release of the MSX and get the whole thing.
#9366
#9367
About the TRF415MSX Conversion Kit.
http://www.tamiyausa.com/product/ite...oduct-id=49378
Question for the Tamiya sponsored guy who have run 415MSX...
How stiff is it compared to a 3mm chassis 415? I like some of the feature that the new bulkheads allow for but I am wondernig how stiff the chassis is. Mainly because I run foams on carpet most of the year.
#9368
maybe a daft question, but if anyone has seen the msx chassis, whats the difference. i can't think of anything that has changed like cell slots, screw holes etc...?
#9369
I'm not 100% sure, but remember this is aimed at a TRF 415MS upgrade (i.e. 2.5mm lower deck) - I'm sure someone said the MSX had a different thickness of lower deck???
It won't need the screw holes for the chassis stiffeners for the mid-decks coz it doesn't have any, I'm sure the standard chassis plates will fit the MSX bulkheads.
#9370
Suspended
415
ok guys,i got my 415 today......what are some options to get?motor?esc?
#9372
Suspended
Originally Posted by LoSi xXx S
What class are you going to be racing?
#9373
Has anyone run a car with the "X" blocks on their car like in the worlds upgrade
kit. If so what did you find out?
PS I think 200 is a good guess for the msx is not that bad those bulkhead's take a lot of machining. It will be nice to remove a diff, or switch between the one-way, or spool without taking a lot of the car apart. JMO.
James
James
#9375
Hey guys where are you buying your spools from as well as general spare parts...Im having trouble finding anything here in GA?
Looking for a good virtual hobbyshop.
Paul
Paul
