Tamiya TRF415
#8791
Can someone help me get this straight
the rear hubs for a 415
TA04 stock rear hubs = 0 degrees toe
TA04 Hard rear hubs = 1 degree toe
TA04 toe-in rear hubs = 2 degrees toe
Is this right??
Is this right??
#8792
nope. Stock TA04 hubs are 1°. The rest is right.
#8793
Originally posted by Burlap
Tryhard, what advantages do you see with putting the grub screws into the plastic stabiliser holder thingies at the back there?
I did this mod last week, just to keep the roll bars from moving around in the mounts. Really only need to tweak the grubs tight, just to make sure the bar still moves freely.
HiH
Ed
#8794
Anyone try rear solic axis on TRF415? I got extra rear diff and thinking about moding it as solic axis, but is it any good for TRF415?
#8795
Originally posted by raffaelli
Whoooo! Car is sold! Cash in hand!
#8797
Tech Legend
Trader Rating: 51 (100%+)
Are most of you guys that run the stock 415 suspension use the 2 hole piston or the 3 hole piston. I have the 2 hole piston setup on right now but I have another set of Tamiya shocks and was thinking of putting 3 hole pistons in them. I only run asphalt with rubber tires if that helps any. Most setups I see seem to favor 2 hole setups.
#8798
#8799
Sometimes when traction is really good the 2hole piston can give you more cornerspeed, but keep in mind that they will make the tires work harder (Overheat faster).
#8800
Tech Legend
I think I will build them with 3 holes and that way I have a set of shocks with both pistons in them and can try them and see what I like. The track I race at now has monster traction. Inddor asphalt.
#8801
Build the 3holes with Tamiya 400 oil and the 2holes with 300, then run them back to back and check out your laptimes..... you will notice that the 2hole piston will make the car more responsive!
Let us know what you think!!
Cheers,
Eirik Andreassen
Cheers,
Eirik Andreassen
#8802
Tech Legend
Cheers,
Eirik Andreassen
Cheers,
Eirik Andreassen
#8803
Oil weights
I run on medium grip asphalt and run 2 holes in front wht 35wt & 2 holes in rear with 40. Car really digs in on the corners and Chicanes. I am easily the fastest in and out of turns at our track. I am also using yellows front and rear with read stabilizers front and rear. I have abother set of srpings on order and plan on trying softer spring with thicker oil to see what kind of action I get. Right now the car is dialed as hell.
Eirik, have you guys experimented with a center oneway and a front dif? I have been using this setup for a few weeks and the car is much more predictable.
#8804
Tech Legend
I might do 40wt with 3 holes that way I will have a good comparison if I use the same oil but different piston. I might get a better feeling that way.
#8805
Just a FYI, Tamiya yellow 400 included in the kit is closer to 30wt.
