Tamiya TRF415
#8626
I would assume that it could be used with both, just like you can use the std front end and lwt rear (not that i've tried, but theres no reason as to why it wouldn't work).
Probably see most benifit from using it with the lwt suspension front, i would expect.
Still waiting for it to come up at speedtech...
Ed
Ed
#8628
Tech Legend
Trader Rating: 51 (100%+)
Originally posted by JDM_DOHC_SiR
Man I can"t wait to try this out on my EVO4 MS .. the quality looks second to none
-Dave
-Dave
#8629
Originally posted by littleZEN
DJ...what about a pro-module front suspension?? Or is that just not possible?
TryHard-
As rtypec mentioned, the toe is 0 deg. and the bearing size is 5X9mm. Also, your right, the Pro-Module Front version has enough driveshaft clearance. It's the steering of the front tires that made it a little more difficult.
mr_postman-
The suspension can be used with the original 415 front suspension but it was intended to be used with the lightweight reversable type found on the Evo IV, Evo IV MS and 415MS so I don't know how well it would work but it will work.
JDM_DOHC_SiR and wyd-
My Evo IV/Evo IVMS set-up should be posted on the Tamiya site very soon as well.
#8630
Originally posted by David J.
Actually, the Pro-Module Front system is in development. In fact, it's pretty much done design wise but still requires testing so if it's released, it won't be right away.
#8631
Re: PMRS
Originally posted by mr_postman
Is the "Pro-Module Rear Suspension" for use with the 415MS only, or can it be used with a "stock" TRF415 suspension also. Sorry for the silly question.
TC
CoBroRa/TAOB
TC
CoBroRa/TAOB
David Jun - will the results be similar with the 3.0mm chassis as the 2.5mm MS chassis ? Thanks-
#8633
Re: Re: PMRS
BTW, for everyone that intends to use my set-up as a base line, if your track conditions are medium to low grip and the car slides too much because of it. Try lowering the inside upper links evenly 1mm (front and rear). This should improve grip under less than ideal conditions.
#8634
I can't wait to try it out! My only concern is the price of replacement arms should I need any. When are those going to be available?
#8635
Tech Legend
Thanks David. Great to have you on here. The new suspension is very interesting. Once I run my car a few times I will then decide what I need to do to make it better. I'm going to run it pretty much stock and see what it does on the asphalt. The stock suspension is really nice since it is very strong.
#8636
#8637
Spare arms and hubs are also available now. MSRP for each is $19.99 and they are strong dispite their light weight. Also, they are almost impossible to wear out unless you do manage to bend one. rtypec has done a lot of testing with me and we have yet to bend one but we haven't been intentionally trying either. Although, rtypec has done some fine impersonations of Mary Lou Retton getting it wrong though the "kink" as well as down the straight away last week. Delaminated his chassis and bent his hinge pins on that one but the suspension was fine.
thanks
-Dave
#8640
David send a set up to Seattle to Kevin Michellich if you need the durability testing. He has a Major in Tamiya parts durability. I think the vid in Japan @ corporate is of one of his cars in an encounter with the wall......
Had any interesting canyon runs lately? The Z is dong real nice power wheelies again.
