Tamiya TRF415
#6901
R/C Tech Elite Member
Originally posted by forty6
That would be cool if you can piece one together. You probably want to take all the measurements then call MIP to see what they have close you what you are looking for.
#6902
Thanks Ed.
Nice one, i've saved it this time
The rock is my closest track, I figure I can copy most of that setup onto the ms (when it gets here!) then tune it and learn the car at the same time.
Works in theory anyway.
Have you raced it much lately?
#6903
Hi,
I'm looking for black low friction belts. Do you know, guys, who makes these parts?
Are they as goog as the tamiya white ones?
#6905
Originally posted by Hugo
Hi,
Hi,
#6906
Originally posted by rtypec
There are a number of Japanese companies that sell black low friction belts. If I remember correctly, Rush was one of them. I haven't used any belts from any other companies but you can try looking through Speedtech's site for some and perhaps dropping Steve a PM. You can also try the Japanese sites if Steve can't get a hold of them.
TECH
ECHO
RUSH
TAMIYA
OVA
they are all close in price but the ECHO and OVA belts are the thinner of the abouve belts
-Dave
#6907
Yokomo RaySpeed MIP CVD bones are 44mm.. if that helps any.
I currently run an after market low friction black belt on my car. I forgot who makes it though... Maybe Echo?? I don't remember. It's posted like.... 6 months ago hehe... I got that one before the Tamiya White belts came out. If you do a search you can find it.
#6908
cvd's
#6909
Go to SpeedtechRC... it's the only CVD's that RaySpeed sells. It's for the SD.....
#6910
Re: cvd's
Originally posted by Raul Garcia
Kilruf, would the fit, I think so, which yokomo?
I don't think it will work because of the drive cup clearance, this is a pic using the A-bridge/C-block with the stock 42mm dog bone, now if the Mip is 44mm I don't see how it will work but I assumming that it will work with the D bridge
#6911
Re: Thanks Ed.
You might want to try running the outswept arms on the front too.
Some useful pointers that might help...
On the MS, position 3 for the lower shock arms is equivilant to the outer hole on the std arms.
Also, run the camber links in the kit setup for the MS, with the Std suspension is different from the one for the lwt suspension.
Also use B for the rear hub carrier upper camber link.
Unfortuantly I haven't had much chance to race my 415 recently, i've got a number of things to try out on the car before the next BIWS round... mainly new batts and narrower front blocks.
Hope it helps
Ed
#6913
CVD's
The MIP question got me digging thru my old stuff box,
MIP # 1450 Kit KAWADA SV 10
The outer stub axle hex pin hole is 2mm further out than Tamiya, but the dog bone is 46mm.
This might help with foam tires for clearance, then use the Worlds susp blocks to bring the wheel base back in..
I measured this off my lightweight kit.
I will check with Dan Garber to get his opinion tomorro.
Fred
Fred
#6914
Drive cups are not a problem because you can always switch them to EvoIV/LW drive cups which sit further in. You can always space those outwards if needed.
#6915
Originally posted by JDM_DOHC_SiR
Low friction belt makers for the 415
TECH
ECHO
RUSH
TAMIYA
OVA
-Dave
TECH
ECHO
RUSH
TAMIYA
OVA
-Dave
