Tamiya TRF415
#6032
If your diff is loosening during the run, I'm guessing your nylon lock on the nuts shot?
#6033
R/C Tech Elite Member
Originally posted by Sushi Boy
It's those crazy 6 turn motors we send you randy...... lol. I never remember having that problem at nationals or when I had my evo 3........
-Korey
-Korey
PM me with your e-mail addy and I'll send you that setup sheet.
#6034
Originally posted by TryHard
Thanks for the pic, it clears up (in my mind at least) what everyone has been talking about, with reagrds to flipping the blocks.
Just a few questions for you though.
1) what screw length are you using to hold the blocks in?
2) have you had any problems with blocks bending when set like this? I had a couple of blocks bend big time on the rear when running 1mm shims underneath, hence why i invested in a set of Evo4 blocks for such situations.
3) also whoose diff pulley is that mounted on your car??
Regards
Ed
Regards
Ed
2) ...not yet (knock on wood). They are undoubtedly more vulnerable this way, though. The effect on the car's handling is well worth any risk as far as I am concerned.
3) Actually, the diff pulley is completely stock; it is the outdrives that I modified. I filed a flat area on the diff outdrives and glued a shield on to keep carpet fibers out of my diff. The shields are not actually connected to the pulley, they just barely rub against it. The outdrives are actually modified EVOIII units. I just made another out of delrin just yesterday...here's a pic.
#6035
carpet fibres are a royal pain in the a**! I feel I'm always rebuilding diffs to clean the fibres out.
#6036
welcome to carpet racing my friend go buy youre self a set of very fine twizers (bad spelling)
#6037
Originally posted by Arun
1) When I built the car for the first time, I replaced all the black screws with stainless steel screws, which happened to be a little longer. The actual length is just over 10mm.
I've been thinking about the block flipping idea, and I can see how it works (lowering roll centre) but I wonder would it not be easier to run the 414 blocks, which i believe are 1mm lower than the 415 blocks? would this not acheive the same effect with out problems with vunerability by placing them so high on spacers?
Thats not ment as a knock to the technique, more of a general query, just to see if anyones tried the 414 blocks as well, and if so does this result in the same effect?
Anyway, time for bed methinks.
laters
Ed
#6039
Originally posted by rtypec
Neil, if you don't want a flexy nut holder try using the holder from 50877 TA04 Ball Differential Pulley parts. It'll let you really crank down on the diff screw without the plastic bit boogering on you.
#6042
I like that diff idea, very clever. might have to look into doing that on the rear, I have a spare set of plastic outdrives I can try it on.
laters
Ed
laters
Ed
We considered the 414 blocks at first, but, as far as we knew, they did not make an A bridge. I never had a 414, so correct me if I'm wrong.
#6044
I put the shield on both my front and rear diffs. The plastic that I used is the "plastruct" stuff that you can find in hobby stores, and I used shoe-goo to glue them to the outdrives.
#6045
Integy shows some premade covers, but i havent used them. they show for the 414/TA04, but i figure they should fit the 415 also...
http://integy.automated-shops.com/cg...31104340702.8e
