Like Tree3Likes
Tamiya TRF415
Old 12-06-2004, 04:47 AM
  #5311
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Ballsie
How do you find the ceramics - are they much smoother than even the tungsten ones? I've heard they really eat into the diff rings tho.
The Ceramics are Super smooth and I have yet to have any wear issues with them at all
-Dave
JDM_DOHC_SiR is offline
Old 12-06-2004, 05:51 AM
  #5312
TryHard's Avatar
Originally posted by racer
what would be the average droop settings for carpet front/rear?
would it be ideal to have the front/rear setting even?
larger droop at the front than the rear and vice versa?
any help would be greatful.
Thanks!
Depends on how you like the car to handle
I had been running #4 front and #5 rear on my car for a while, but I've now switched to #4 on both ends. thats measured with a yokomo gauge on the same point on the outer pins on the suspension arm
Basically if you need more front end into the turn, increase the amount of droop on the rear. If you need more front out of the turn, decrease the amount on the front (restricting weight transfer to the rear, reducing the rear grip).
HiH
Ed
TryHard is offline
Old 12-06-2004, 06:14 AM
  #5313
kentech's Avatar
Originally posted by JDM_DOHC_SiR
Hara Used a EXCEL Accord body along with 90% of the Other A-Main drivers.. there is a slight difference on the shape of the front lip and hood line on the Excel Accord...and the Rear wing is different
-Dave
Thanks for clearing that up. That's why I said "I believe..." Does the Excel version have more or less front downforce then?
kentech is offline
Old 12-06-2004, 08:21 AM
  #5314
Originally posted by kentech
One more with the electronics installed.
Wow nice car , makes wana get one now
Chazz
Chazz is offline
Old 12-06-2004, 08:23 AM
  #5315
Can you use associated tc3/4 springs on the 415 and IV, wanna know as i'm considering one of these two cars and cannot find a website which sells tamiya springs online
Chazz
Chazz is offline
Old 12-06-2004, 08:36 AM
  #5316
Yes you can use Associated Springs no problem.
190mph is offline
Old 12-06-2004, 08:47 AM
  #5317
Oh good, at least that's one thing i don't have to worry about if i get a tamiya
Chazz
Chazz is offline
Old 12-06-2004, 09:27 AM
  #5318
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Default Re: TRF415MS pictures
I promised some better pictures earlier. Here they are.
That looks hot! Great job on sealing the carbon parts. I'm expecting my package today (well I was expecting it saturday, but today will have to do)
All that blue, it looks soooo good.
Randy Caster is offline
Old 12-06-2004, 09:30 AM
  #5319
Default Re: Ceramic Diff Balls
Has anyone tried the Xenon Racing ceramic diff balls or any kind of ceramic diff balls?
What kind of lubrication do you use with them
Cheers
I've used Acer ceramic diff balls in the past with good luck. They were very smooth and lasted forever. AE silicone diff lube was my choice.
Old 12-06-2004, 09:31 AM
  #5320
Chazz
I did a search and found the Tamiya springs on Tower Hobbies' website, but that is the only place I could find em.
Old 12-06-2004, 09:52 AM
  #5321
JasonC's Avatar
Trader Rating: 120 (100%+)
hey Randy Socal and Ultimate have Tamiya springs in stock
JasonC is offline
Old 12-06-2004, 09:56 AM
  #5322
Default Servo Horn
From which manufacturer is the servo horn (aluminium blue) that M.Rheinard and S.Maezumi were using at the worlds.
I can see in the pictures that is a long one.
Hugo is offline
Old 12-06-2004, 10:16 AM
  #5323
Default Re: Servo Horn
Im not sure who made the one they are running, but check on Speedtech's site under servos and they have one that looks like it could be it.
Old 12-06-2004, 10:17 AM
  #5324
I know, but he was lookin for a website with them...
Old 12-06-2004, 10:19 AM
  #5325
Default Re: Re: Servo Horn
Yes I've saw that one, from racer's edge, but I'm not sure it's a long one.
Does someone have the one from racer's edge?
Hugo is offline
