Like Tree3Likes
Tamiya TRF415
Old 11-01-2004, 05:00 PM
  #4561
SpeedTech's Avatar
Originally posted by vi3tishduy
Ok, I think i've made my mind on what car I want to purchase...... Out of these cars, Pro4, R3, Mi2, Evo4, Trf415. 415, and the Pro4 are my top two choices, but since the Pro4 is chaft, and i have a shaft, i'll get the TRF415,. Anyone know where I can get one for a cheaper price than 349.99 er, I think it was 359.99. www.ultimatehobbies.com is the site. Steve, can you match the price? They also offer freeshipping. Thanks....
vi3tishduy,
Please email me or call me, I'll see what I can do. Thanks
Steve Wang
SpeedTech is offline
Old 11-01-2004, 05:25 PM
  #4562
vi3tishduy's Avatar
Thanks. I'll call you if I can some time this week, I just need confirmatoin with my mom.
vi3tishduy is offline
Old 11-01-2004, 05:37 PM
  #4563
jeffreylin's Avatar
Originally posted by Hebiki
jeff.. you racing tomorrow?
Are you? I will if I can get my work done in time.
jeffreylin is offline
Old 11-01-2004, 06:26 PM
  #4564
SpeedTech's Avatar
vi3tishduy,
Because you're underage and the card is not under your name, if you need to place an order, please make sure she is near by as well (I would need to speak to her on the phone to confirm the order) Thank you
Steve Wang
Old 11-01-2004, 06:29 PM
  #4565
JimmyMac's Avatar
Just Curious, but does anyone know if the 415MS "will" be the Worlds kit... or will there be a 415 WCR kit after the 415MS is sold? Dave? Any rumors? Steve?
JimmyMac is offline
Old 11-01-2004, 06:49 PM
  #4566
Regional Moderator
kumpol's Avatar
Tamiya World Champion Team at the 2004 worlds
(missing Martin Crisp)
kumpol is offline
Old 11-01-2004, 07:02 PM
  #4567
Regional Moderator
kumpol's Avatar
kumpol is offline
Old 11-01-2004, 07:07 PM
  #4568
Regional Moderator
kumpol's Avatar
kumpol is offline
Old 11-01-2004, 08:12 PM
  #4569
Hebiki's Avatar
Trader Rating: 26 (100%+)
if i wake up in time! then i can pack/load my car before i leave for work.
Hebiki is offline
Old 11-01-2004, 08:38 PM
  #4570
|8t
|8t's Avatar
I just get my low friction belts + belt stabilizer.....The front belt tend to wave from right to left on the pulley...Is it normal or there is a way to correct that? Sorry I'm newbie to belt drive system...How do you set the tension on the belts?? Factory setting is like rear too loose and front little bit tight...Any tips for me? Also I cant get my car free like my old shaft tc3....Is it possible?
|8t is offline
Old 11-01-2004, 08:52 PM
  #4571
BlackKat's Avatar
I tightened the rear belt one tooth and left the front at stock setting with no problems....Outpuched & outdragged a TC3 with my unmatched batteries and a fresh out of the box, untuned Epic motor if that means anything
I think the waving is normal (note: I use the stock belts) I never really worry about how long my drivetain spins compared to other people. As long as it spins a good few seconds smoothly & doesn't bind I'm cool. I don't think having a drivetrain that can compete with Lex Tyler's for longest spinning will increase my lap times at a club racing level
For outdoor asphalt & parking lot surfaces...do yourself a favor and get an A bridge block right away or else you'll be pushing out of the corners like a dump truck!
And I hope you don't get the wrong block in the mail like I did... Cost me the A-main win! Theres always next season
BlackKat is offline
Old 11-01-2004, 09:04 PM
  #4572
GT Racer's Avatar
Hi, sorry I'm new to Tamiya cars. just got my TRF415. So which and what is A bridge block?
GT Racer is offline
Old 11-01-2004, 09:07 PM
  #4573
SpeedTech's Avatar
You can help control how the belt ride on the pulley with some 10mm shims and the center belt tensioner also help guide the long front belt. Belt tension is adjusted in the bulkhead. Run the car with the belt in stock tension for about 1 race weekend and then tighten it up I have my belts about 2 clicks tighter.
Steve Wang
Old 11-01-2004, 09:08 PM
  #4574
SpeedTech's Avatar
GT Racer,
The A Bridge block is for the front of the car (the kit comes with D Bridge block) The A bridge block is narrower than the D block and it will sweep the front hinge-pins back a bit to help the car turn in a bit more.
Steve Wang
Old 11-01-2004, 09:22 PM
  #4575
dawgmeat's Avatar
Default battery brace
I'm sorry but I just don't trust battery tape
dawgmeat is offline
