Tamiya TRF415
R/C Tech Elite Member
What parts do I need to buy for my MSX to get it to MRE spec as far as centre pulley / drive train goes and also wide pitch Pulleys. Am running a front one way (Would I need to buy an MRE one) and fixed centre.
Also with an MRE chassis, is there anything else bar changing to Evo 5 Steering (and changing top deck) that needs to be done to bring it up to date?
setup for asphalt
i need trf415 msx setup for asphalt. i currently use sorex tire.
nino pohan: The kit setup for the MSX works great for most ashpalt tracks. If you run on a track were the traction is low, then go a little softer. Either go down to 30 weight or drop to a softer spring.
Mi2dude: I believe "the movement" you are talking about can be easily fixed by placing a shim in between the wheel hex and hub carrier. Check out Speedtech for a wide range of different sized shims.
Originally Posted by razzor
Anyone do the TA05 gear and spool conversion on the TRF415MS ???
wanted to know if its worth the effort.
Found the info here http://www.thard.co.uk/tips/
Well I hate to do this but, I must.
UP FOR SALE!
OFF To Ebay... CLICK HERE
Like New Condition 415 MSX MRE Limited Edition. Plus over $100.00 in spare parts and hop ups. (No electronics Included)
Only Raced on Carpet! Ceramic Bearings throughout, Titanium Screws, Aluminum Front Steering Hubs, Front Spool, Front Oneway, AND Front Diff - Plus More. Also Includes original box and instructions!
REDUCED PRICE...!! $350 takes ALL..! No Trades - Paypal only.
Shipping included.>Continental US<
If overseas shipping and insurance will be at your expense.
PHOTO'S HERE
UP FOR SALE!
PHOTO'S HERE
Can someone with a MSXX confirm this for me:
I was reading the PDF file to the MSXX instruction manual, and the bottom plate/deck has extra holes up near the steering ackerman which are not used. From what I can guess, it looks like you can fit the older MS/MSX steering setup on it. Am I right in saying that?
Hi, anyone know can i use teh racing MY05 or MY07 rear upright to Tamiya TRF415MSX
Originally Posted by TRF415boy
Yep and that's exactly what i'm doing since precision have been so rubbish and forgot to put the steering posts and bellcrank in my package . Do not buy off Precision RC...
AARRRGGHH!! I just did an order for an MRE Chassis from them (my MSX chassis is a bit hammered and I want to run the motor duct and TA05 Pulleys anyway
Goddamnit!
I wouldn't worry too much... Precision are th eguys who I ordered my replacement MRE chassis from last year (after it got nailed against the armco at west london ), arrived in good time, with everything else in the box.
Seems every once in a while an order slips through...
Ed
Ed
Well it's 540 comp the next two weeks (540-J and Sports Tuned) so it should limp through!
Besides the maintenance issue, are there any other things about the MSX that make it better than the MS? I am running 540, so would upgrading make much of a difference?
Yep
