Like Tree3Likes
Tamiya TRF415
Old 04-10-2007, 11:15 PM
  #18076
RC MARKET's Avatar
Originally Posted by sohlman
Here's a top view of my MRE's electronics. I hope it helps. I still need to shorten some wires.
Good !
RC MARKET is offline
Old 04-11-2007, 04:42 PM
  #18077
Leester's Avatar
Trader Rating: 23 (96%+)
Hello Folks.
I would like to know what is the best suspension arms to get for the 415 on carpet and where can i buy them? Thank you
-Lee
Leester is offline
Old 04-11-2007, 06:18 PM
  #18078
Burlap's Avatar
Originally Posted by Leester
Hello Folks.
-Lee
Which version of the 415 do you have? If you have the original one, then those arms are great. If you have a MS or later, get the Evo V short arms, as the uprights/c-hubs from the MS/MSX/MRE/MSXX fit it. You need to get wider toe blocks however for the Evo V arms. I run E-D (bridged) at the front and 1XA - 1D at rear.
Burlap is offline
Old 04-12-2007, 07:03 AM
  #18079
jhigga15's Avatar
Hello everyone,
I have an EVO 4 MS. I was in a bad crash and bent the steering arms. Are they the same ones that are used on the TB02R and the 415?
jhigga15 is offline
Old 04-12-2007, 07:31 AM
  #18080
infokiz's Avatar
Get The TB02R ones they are a perfect fit I had the same thing happen on my EVO4 twice and when I switched to those it worked perfect.
I don't know if the 415 ones will fit I never tried those.
infokiz is offline
Old 04-12-2007, 07:33 AM
  #18081
Default setup
heres the setup i used from the fastcats race.
File Type: pdf
TRFwhitey is offline
Old 04-12-2007, 07:34 AM
  #18082
jhigga15's Avatar
Thanks INFOKIZ...I will try it, if it does not work I know where you post...lol.
I have been dying to get my car back in action...
jhigga15 is offline
Old 04-12-2007, 12:00 PM
  #18083
infokiz's Avatar
No problem glad I could help. After bending 2 sets of the EVO4MS bellcranks that was the only solution I could come up with. I happened to have my TB02R with me at a race and gave it a try as they are identical in size and shape.
I was looking at a few of my 415 manuals and although those ones may work they are a diffrent size and shape and may adversely affect the steering.
infokiz is offline
Old 04-12-2007, 12:34 PM
  #18084
Leester's Avatar
I have the 415 MSX conversion. What are the part numbers for the wider toe blocks?
Leester is offline
Old 04-12-2007, 12:45 PM
  #18085
Leester's Avatar
and also what is the par number for the 415MSXX lower chassis? and will it fit on my 415 converted to a 415 MSX?
Leester is offline
Old 04-12-2007, 04:20 PM
  #18086
Burlap's Avatar
RC Mart have them. The part number is 9404735. Here is a link to the page:
http://preview.tinyurl.com/344vse
There seems to be extra holes where the old style (415/MS/MSX) steering posts could go, but not too sure. Might buy one soon as the old lower deck is wearing away on my car.
Here are the part numbers for the wider toe blocks, including the bridge D block, which you need for the front end:
1x 1D Bridged toe block Part# 51064
1x 1D toe block Part# 51068
1x 1E toe block Part# 53896
Burlap is offline
Old 04-13-2007, 08:35 PM
  #18087
Trader Rating: 68 (100%+)
i am new to tamiya cars and i bought 2 mre's. i need a carpet set up with the short arms. i also have the 6mm hexes. i run stock/foam/carpet. thanks for any help.
todb is offline
Old 04-14-2007, 08:24 AM
  #18088
sohlman's Avatar
Trader Rating: 92 (100%+)
Try this setup...it worked pretty well for me.
sohlman is offline
Old 04-14-2007, 10:50 AM
  #18089
quantum's Avatar
Default arm selection
is there a general rule of thumb on when to use the shorter evo5 arms?
i know lots of ppl use them on the msx when running foam carpet, but is it advantageous to use with rubber asphalt or rubber carpet in 19T?
what exactly does the shorter arm do?
quantum is offline
Old 04-14-2007, 06:11 PM
  #18090
car is quick but loose in the rear and lose pushes out mid corner. i was just playing around though. real work tommorrow. should be fun.
todb is offline
