Tamiya TRF415
Anyone using Fr 1way for the MRE? What are the parts (part no.) needed to buy the conversion? I am quite confuse, some uses the Ta05 oneway gear and some use the 415.
From what i research the following is all i know,
Tamiya (#53704) TRF 415 Lightweight Front OneWay Cap Joint
TAMIYA (#53947) TRF415 MSX ONE-WAY
Tamiya (#53936) TA05 Wide Pitch Front One-Way Pulley (36T Size) OR
OR
TAMIYA (#51054) TRF415 FRONT ONE-WAY PULLEY (35T)
so which one fits better?
OR
OR
OR
These two are the ones you want. Do not try to fit a 35T pulley on the MR one way, it won't.
OR
OR
Originally Posted by RC MARKET
use 36T pully need change belts
So should i run 23T stock motor with spool or 1way?
erm so i need a belt change?
Originally Posted by TRF415boy
Depends what car are you running ? MSX or MRE ? I understood that you were using the MRE am I right ? If so no need to change the belt.
Another question is should i also change the center 1way?
rear hub
guys, can i use ta 05 or trf 415 ms plastic rear hub on my MSX???? b'cos i wrecked my MSX's alum rear hub and my LHS out of stock that item. is the geometry will change???? please PM me bcos i'm not on line regularly....thanks guys...
OR
OR
If you use the 415 MSX - MRE 1-way or spool, you must use the white TA05 regular or wide pitch (less notches) pulley.
Trying to use any other way will need modifications.
R/C Tech Elite Member
A TA05 hub from a lightweight suspension set (such as on a TA05R) will fit as well.
do i need center 1way if i install front 1way? what's the use of center 1way? sorry still learning.
Chassis question
Guys...quick question...Is the main chassis of the MRE the same as that of the MSXX?
Thanks.
Thanks.
Thanks.
Thanks.
Thanks.
Thanks.
HiH
Ed
