Tamiya TRF415
Originally Posted by chris_morrison_
they have an live inventory
and so if it goes into your cart it is in stock
i just got $330 worth of parts from the last week
i just hope youve left some for the rest of us
anyone know whos got a tir racing titanium Superlite Input Layshaft in stock?
for the msx mre.thanks
Originally Posted by TRFwhitey
Anyone in need of a carpet setup? Heres mine..up here in canada we do ALOT of carpet racing so heres a refined setup i have used at vegas, cleveland, novak and magma races.
Front:
x-ray 25lb spring
60wt w/ 2 hole piston
3rd hole down on shock tower
inner most hole on susp.(short arms)
4 degree caster
1.5 camber
longest front link with 3.75mm shims under inner link
D/D blocks with .5mm shim under both
.5 degree toe out
blue (kinked) swaybar
1mm droop
wheelbase: 6mm behind front arms
HPI pro4 knuckle/bearings with older tamiya axle(orig axle from 415MS)
PARMA magenta with glued edge
Rear:
x-ray 17.5lb spring
40wt w/3hole
3rd hole down on rear shock tower
inner most hole on susp. (short arm)
2 degree camber
0 degree rear hub
2.5 degree rear toe(3 when grip comes up)
camber link: inner hole on bulkhead and middle hole on hub w/ 1mm spacer under outer link and .5mm under inner
X/D blocks with .5mm shim under both
wheelbase: 6mm in front of rear arms
yellow swaybar
1.5mm droop
PARMA magenta unglued
Front:
x-ray 25lb spring
4 degree caster
1.5 camber
.5 degree toe out
1mm droop
Rear:
x-ray 17.5lb spring
40wt w/3hole
2 degree camber
0 degree rear hub
yellow swaybar
1.5mm droop
re
yes the setup is for mod! i don't race stock ...however i do use this same setup for 19t.
sorry if this question has been asked before, but by looking at the kit instructions for the MRE and the MSX, the drive belts have the same part number. there is not a part number for the belts on the MRE insert. can the low friction white belts be used on the MRE?
thanks
vic
thanks
vic
yes the standard belts fit
and the white belts
and the white belts
thanks
vic
thanks
vic
If you plan to run white belts, be sure to adjust the bearing holder much looser. White belts are shorter than MRE belts.
thanks
vic
thanks
vic
6245014 Rear
im sure ive read on here that the belts have a slightly different pitch.but work all the same?
after running the MRE today i've noticed that my two rear tires wiggles a lot thought that i might have not tighten the wheel nuts but when i checked them they are tight checked the dogbones if bent but they are straight any of you guys encountered this problem
for the msx mre.thanks any ideas????
thanks fab is tir not that good then? ive been eyeing up some worlds edition driveshafts too.now whats your thoughts on those?thanks
