Like Tree3Likes
Tamiya TRF415
Old 12-25-2006, 05:05 PM
  #16831
TRF415boy's Avatar
Hi Adam,
No problems there, the wide pitch are the same as the TA05, only with half the teeth on the pulley, if that makes sense.
TRF415boy is offline
Old 12-25-2006, 06:44 PM
  #16832
Wing Chun's Avatar
Thank's Mate,
I hope santa brought you a lot of new thing's ha ha
Addam
Wing Chun is offline
Old 12-25-2006, 06:52 PM
  #16833
What is the part number for the front back arm mount in MRE. I know it is 1A. But what is the part number? thanks!
ioxqq is offline
Old 12-25-2006, 11:51 PM
  #16834
Stein Tumert's Avatar
Art.-Nr.: 51065
Stein Tumert is offline
Old 12-25-2006, 11:59 PM
  #16835
Thumbs up
Originally Posted by racer43
yes, the motor is stock trinity co27 an the track is asphalt
If you run the original 102T spur gear, it is 0.4 module. I would start to test 35 to 40T pinions on your car in 0.4 module pitch. It will depend on your track, batteries and if your motor is well maintained where you end...
You can alternatively change everything over to 64 pitch stuff, both spur gear and pinions.
The 64 pitch pinions will work with the 0.4 module spur gear, but it is not a 100% fit.
Old 12-26-2006, 04:26 PM
  #16836
Wing Chun's Avatar
Man it's hard getting parts for the MSX here in OZ. I got on the internet and found some TA 05 Wide pitch pulley's at
rcmodel.hk Online R-C Model Shop
I looked every where and they where out of stock, after trying 11 different shops these guy's had some.
Thanks Addam
Old 12-26-2006, 04:37 PM
  #16837
If you're in OZ, maybe you should go see the wizard. Maybe he can hook you up
DOTMAN is offline
Old 12-26-2006, 05:41 PM
  #16838
hierog's Avatar
try www.speedtechrc.com, www.precisionrc.com and www.rainbowten.co.jp/english/
you should be able to find EVERYTHING at Rainbowten
vic
hierog is offline
Old 12-26-2006, 05:56 PM
  #16839
Charles Godwin's Avatar
RcChamp are great, cheap prices, fast shiping and extremely fast and helpful at returning e-mails
Charles
Charles Godwin is offline
Old 12-26-2006, 06:00 PM
  #16840
Kenneth Tan's Avatar
Default H0 and H rear hubs
Hi,
May I know are the handling differences between the H0 and original evo IV 0 degree aluminium rear hubs? Thanks.
Kenneth Tan is offline
Old 12-27-2006, 05:05 AM
  #16841
Thanks Addam
Addam, email RC Champ in Japan. They are very good. I usually have stuff from Japan to Germany in 4 days when I order from them.
Old 12-27-2006, 07:49 AM
  #16842
Mi2_Tastic's Avatar
DO NOT use Precision RC they are mega rip off merchants, didnt send me the stuff that I asked for and then charged me for it anyway.
Mi2_Tastic is offline
Old 12-27-2006, 10:20 AM
  #16843
freekthefreak's Avatar
hmm...
i ordered from them last week
had 1 problem because they did not "see" the order but i send them an last wednesday and he got right on it (thursday at that time) but saturday the mail-man had the package with him
so i think they did a pretty good job
freekthefreak is offline
Old 12-27-2006, 01:30 PM
  #16844
Hi guys.
I just wanted a quick bit of advice. I need to get some new spurs and pinions. I will be running a checkpoint 19t money motor on a small to medium sized carpet track. I normally run stock so need a bit of gearing advice for 19t. I run my stock at 8.0. much appreciated.
blakeyx is offline
Old 12-27-2006, 01:59 PM
  #16845
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by blakeyx
Hi guys.
What pitch gears do you want to run?
veecee is offline
