Tamiya TRF415
#1636
Hello,
I have just purchased a new 415 at my LHS. It will be my 19t/modified car. I am new to Tamiya (well, I owned a Frog back in the day) and am unaware of any tips or tricks that the Tamiya guys have been using. Any help or recomendations would be great.
Also, for the guys already running the 415, can you recommend what spares or additional parts I will need? Modifications?
Thanks in advance!
Joe
Thanks in advance!
Joe
#1637
LRP Race
Looks like Marc Rheinard won the LRP Touring Car Masters 2004/Germany race against some big names (Surikan, Hara, Spashett, Baker etc). I remember racing against Marc at the Tamiya Worlds a couple of years ago. If I remember correctly he came third. Good Kid and a fast driver. Congrats to Marc and his 415.
Hey Marc, if you read this, please post your setup.
Martin Crisp
Martin Crisp
#1638
hey martin i am trying some speedmind sweper tires on my car for ozite what should i expect oh yeah there 45/40 and 26 mm and i usually run jaco 28mm plaid/purple i was told lot of you guys run this combo should i change any set up on my car? it is for an evo 3 surikarn lt me know thanks.
#1639
Speedmind Tires
The 45/40 compound will have more steering than the plaid Jaco. So you will need to tune your setup to accomodate. I would suggest putting ca on the outside verticle edge of the front tires if you want to reduce some of the steering.
#1641
Originally posted by koabich
Hello,
Thanks in advance!
Joe
Hello,
Thanks in advance!
Joe
The only modification I would suggest are the titanium screws. I did get the alumnium rear uprights but have yet to try them.
#1642
Originally posted by Difuser
...Pickup a set of the TA04 uprights and cut off the camberlink mount. These will give you 8d of caster.
2) thought the original TA04 upright (=8deg) didn't have the ears.
Only the later "TA04 Racing Front Suspension" uprights with the
lesser camber had the ears.
#1644
Re: Speedmind Tires
#1645
Regional Moderator
Re: Speedmind Tires
#1646
thanks, Difuser! i saw that post, but didnt have any of those on hand. i did order the spare pulley from Steve last night. i thought i had it figured out with some MR4TC drives- they fit in the bulkheads almost perfect! but, the total overall length is too short for the shafts to hit well. off to ht eHPI parts bin!
#1647
Other way around the original had the "bump" for the mount position. The reason for cutting them off is that they get in the way of the top ballstud/kingpin.
Me thought you meant the rear ear for the diagonal torque rod (which the earlier higher castor blocks didn't have).
Yep, makes sense now.
Guess the toplink must be sitting further "back" then... have tried old TA04 blocks on EvoIII with link on the shock tower, don't think it fouled the rod there.
#1648
Re: LRP Race
Martin Crisp
Martin Crisp
He was national champion indoor and outdoor 2002 and 3. place 2003. Heīs just 17 or 18 years old now (donīt know exactly) and everybody here wanna know what he can do at this years Euros and Worlds.
Regarding setups itīs easy. Just look for his EVO3 indoor setup. Heīs using the same setup with his 415 as most of the German Tamiya drivers do. Steen Graversen wasnīt that fast with this 415 until he switched to the same setup.
#1649
diff setup
i thought i had a flash of brilliance with this one, till i looked a little closer. doesnt look like the shafts are deep enough into the outdrives.the center is actually a little too narrow, but could be easily shimmed. anyone hear of a 45mm shaft instead of 42?
oops.. forgot pic! see next post...
