Old 01-21-2009, 09:37 AM   #31
Trips's Avatar
Trader Rating: 16 (100%+)
It's important for the faces of the rings to be flat, I agree, but it's also important for the faces of the ring to be parallel to each other. I'm not of the opinion that hand-sanding can achieve that. On the other hand, if the rings are stamped from a reasonably flat piece of metal to begin with, sanding may indeed remove any high spots induced by the stamping/heat treat, but still not introcude any taper (unless someone sanded on the rings for a week straight...)
Now if someone were to put the rings on a surface grinder and make dead flat dead parallel faces, I'd be buying those rings exclusively. They'd be expensive, but if you're not slipping the diff a set of rings lasts a LONG time.
Trips is offline   Reply With Quote
Old 01-21-2009, 10:09 AM   #32
trerc's Avatar
Trader Rating: 89 (100%+)
Originally Posted by Trips View Post
If you're not slipping the diff a set of rings lasts a LONG time.
Very true
trerc is offline   Reply With Quote
Old 01-22-2009, 01:40 AM   #33
tc3team's Avatar
with the thrust race (the very small circle of balls that goes through the differential centre bolt) after you have put a comfortable amount of grease on the thrust race, put a small piece of foam in the outdrive before you put the driveshaft in.
This will stop any dirt/grit getting into the grease/thrust race and wearing it out quicker
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Hpi Pro 4 Barry White Electric On-Road 16009 08-22-2016 03:17 AM
Academy's new 1/10 scale buggy SBV2 PRO rcforum Electric Off-Road 2964 12-10-2011 11:16 AM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
HB Ask Jeremy Felles Jeremy Felles Electric Off-Road 1101 10-09-2009 11:58 PM
Nitro Sprintcar RevXS Nitro On-Road 30 05-16-2008 04:12 PM
ACADEMY New SB V2 4WD Buggy MatthewCho Electric Off-Road 348 02-01-2007 02:12 PM
SEO by vBSEO 3.5.0
