Old 01-18-2009, 07:14 PM   #1
Mark506's Avatar
Trader Rating: 41 (100%+)
Default Help with Trans-Am setup
I'm putting together my back up Corally RDX, and was wondering some things for starting trans am.
-What should i run my toe in the front/rear?
-Shock weight front/rear?
-Also on the bulkheads, towards the bottom there are those two holes were the hingepin adj. blocks go, should i run those towards the bottom (closer to the chassis) as i would do as I"m running foam, or have them in the upper position?
Thanks, any help, or other suggestions as greatly appreciated.
Mark Ament
l MOMO USA l OZ Racing l Willwood Brakes | Dunlop Tires |
The Raceway at Beaver: Forever In Blue Jeans
Mark506 is offline   Reply With Quote
Old 01-18-2009, 07:49 PM   #2
robk's Avatar
Trader Rating: 22 (100%+)
You can probably start with a good rubber tire setup for the RDX. Usually, any car starts with 3* of rear toe. Also, most cars seem to run well with higher roll centers (hinge pins higher), but that is not always the case.
As far as shock oils go, again, look at rubber tire setups. 40wt. usually is not a bad place to start.
Team Magic G4 Motorman Nitro On-Road 11757 10-11-2016 09:24 PM
E-maxx 3906 with EVX-2 16.8 motor problems tightdog1 Monster Trucks 17 05-26-2009 05:06 AM
May give up Baja 5T and go Flux. Questions abound Freezebyte Electric Off-Road 10 04-18-2009 05:31 PM
XXXT MF2 transmission help please! gee55987 Electric Off-Road 8 04-03-2009 08:10 PM
SEO by vBSEO 3.5.0
