Traction roll cures?
#17
Just trying to get my opinion across to the bloke, he must be kinda confused
with all these different answers.
#19
oooops didnt read that bit!
#21
Leave the damn thing alone. It was about perfect last week.
#24
Hey guys.
I am running on what has become a high traction tight carpet track.
I am traction rolling hard in the middle of the high speed sweeper.
Very entertaining to watch at 45 kph I,m sure.
Would putting on a stiffer roll bar and lowering my inner link location help? Or is there another cure I,m just overlooking?
Come on guys, throw me a bone here.
The barrel roll king, Dave.
2.Raise Link-you want less camber gain. The RC change is very secondary. For that matter, you can take some camber out too.
3. Raise the hingepins. This will take away some traction and reduce the rolling in the car--Is it rolling over the nose and flipping, or just snapping over like the car is on a hinge?? If it's a snap you are too stiff and also have too much traction.
4. Stiffer bar will only help if you are too soft in the first place. If you go too hard it could actually be worse. Worth a try though.
5. Also, as mentioned, try differing dope on the front tire, and use glue on the sidewall. Gluing the sidewall may be the easiest and best solution if your car is working pretty good beside the barrel rolls.
#25
didnt know u were on foams, ca is ur friend.
R
R
#26
Make sure your chassis is flowing and can comforably bottom out often we make these cars too stiff and instead of absorbing energy and sliding on the chassis just a bit they flip and roll. In other words sometimes a softer spring/shock package can help with mid corner flips.
Second to the ca on the edge of the front tire easy and very effective way to reduce front bite and rollover issues
#27
I've also heard of this too. I too have been having problems with traction rolling on certain tracks. I also notice that softening up the rear when the track is loose reduces grip. So I stiffened up the car and gained more traction. Is this right?
#28
If your using rubber tyres, try coating the outer sidewalls of the tyres in superglue (crazyglue or whatever you Yanks call it )
This stops the sidewall from deforming so much and if the roll goes a bit too far the smoothness of the glue helps stop it gripping too hard.
This would be my first port of call as you've mentuioned it's only happening in one place on the track.
Also, no need to compromise the setup for the rest of the track.
Skiddins
Skiddins
#29
That is true.... If you plot the traction (y-axis) vs spring hardness (x-axis), you'll get an inverted U. Meaning you'll increase grip when you increase spring hardness till a point it drops off.
#30
Wow...
Sorry guys I didnt realize this thread had taken off.
Some good info and some I cant use.
The ca on the sidewall I thought was reserved for the guys using foam but it definately makes sense to me that it would work for rubber as well.
Pretty sure I was just over saucing the fronts.
The "U" of traction I like that analogy.
Dave.
Dave.
