Old 10-24-2003, 03:27 PM   #1
holycow's Avatar
Default Silicone Diff grease, Axle thrust grease
Sup guys... I tend to rebuild my diffs semi-often, and from this point on, I refuse to pay 2.50$ for a tiny tube of slilicone diff grease, and another 2.50$ for a tiny tube of axle grease for the thrust bearing! TOTAL RIP OFF
There HAS to be a more economical solution! Is it possible to pick up this exact same stuff from lets say "home depot" by the jug? I know not just any axle or silicone grease will work... so I would need some details
Thanks for any info or ideas you guys might have.
holycow is offline   Reply With Quote
Old 10-24-2003, 08:33 PM   #2
Send a message via AIM to ZER01
$2.50 worth of diff grease should last you a lifetime. You are suppose to use the diff grease sparingly as too much is a waste. Aslo if you "break-in" your diff right after a new rebuild you shouldn't be rebuilding a diff that much. Hope this helps.
ZER01 is offline   Reply With Quote
Old 10-25-2003, 08:59 AM   #3
popsracer's Avatar
You can purchace a "Lifetimes" supply of thrust Grease in the form of an Automotive 'Moly' Grease.
For Diff grease I use 'Dow Corning' #4 silicone Grease. Found at Electronic supplies.
For less than $15usd total, you'll have enough for your Grand kids.
popsracer is offline   Reply With Quote
Old 10-25-2003, 10:33 AM   #4
RCGaryK's Avatar
I know if you are running a pan car, RadioShack Teflon lube works really well. That was my secret diff lube for years when I ran the F103 chassis car.
Site Content Specialist- Surface
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
RCGaryK is offline   Reply With Quote
Does the 8ight-T come with diff oil or grease? Tony899 Electric Off-Road 6 04-15-2007 08:51 PM
Tamiya Anti wear Grease or Ceramic Grease..?? TRFTIM Nitro On-Road 6 04-24-2006 10:52 AM
Diff Grease Bane Rookie Zone 4 03-17-2006 11:24 PM
Hyper 7 Diff Grease? Nickmind Electric Off-Road 1 03-13-2006 08:07 PM
Ball Diff Grease zxt Electric On-Road 6 12-01-2001 04:41 AM
SEO by vBSEO 3.5.0
