Old 08-28-2009, 05:03 PM   #616
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
Originally Posted by dfiantii View Post
Its an upgrade for me since right now I have 3 cars with a transmitter that can only control two. I will hold out though. I will wait and see if I want the R or the S. Right now I am ok swapping between the three cars.
yeah then in your case it is an upgrade....
Alex
hound_dogs_01 is offline   Reply With Quote
Old 08-29-2009, 07:18 AM   #617
avs
avs's Avatar
Originally Posted by hound_dogs_01 View Post
no DSM has a shorter antenna than a DSM2 reciever.... that is NOT a DSM2 reciever dfiantii
Alex
the receiver shown in the ebay link is a dsm receiver which has an extra short antenna, like 4" or so. i copied a setup from the BMI db10 instructions, run the antenna thru some heat shrink tubing over a piece a lexan servotaped to the receiver (hockey stick shaped)
avs is offline   Reply With Quote
Old 08-31-2009, 02:04 PM   #618
tennvol11's Avatar
Trader Rating: 8 (90%+)
rccartips, that's just the one, very tight indeed
tennvol11 is offline   Reply With Quote
Old 09-01-2009, 07:41 PM   #619
bboard's Avatar
I've been following this thread for awhile, and finally get a pic to put up. I don't have any crimpers to shorten the wires so I just tuck them away as neat as possible.
Heres my Leading Edge Hangman, gonna be a 13.5/single cell car, but for now its running 7 sec. breakout class. I still gotta mount in the battery and change the tamiya plug to Deans.
Side
Top
bboard is offline   Reply With Quote
Old 09-02-2009, 08:41 AM   #620
Sohlman113's Avatar
A few pages back there was an S400 with aluminum body posts. They were silver and I happen to like them. I want to know if anyone knows who makes them and if they will fit work on a Cyclone my main concern is the rear ones. Thanks
Jonathan Sohl aka Chicken Little
SMC-Racing/PT Racing Oils/TQ Racing Wire/
Sohlman113 is offline   Reply With Quote
Old 09-02-2009, 01:29 PM   #621
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Yes, those are original batch RP30s. Have a couple sets left, but won't use them till my club has another points series.
I didn't quite get the blue as close as I would like, but its good enough.
The car IS balanced left to right with the PPD plates. Currently I'm about 10grams under depending on body/paint used.
BTW there is a personal transponder in there....but its hidden in the bumper.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 09-02-2009, 07:27 PM   #622
DARKSIDE's Avatar
ok tell it..I did alot of work on my 5 and it doesnt look like that..spill it..whats the 411?
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Scale Nationals
Windy City RC in Arlington Heights IL
April 8-9
DARKSIDE is online now   Reply With Quote
Old 09-02-2009, 11:40 PM   #623
Servo wire is between servo post and huge 3pks RX. I dremeled a slot in the servo post for the wire to get past. Transponder is in the bumper. You can't see it, even from the bottom. The transponder wire is secured by shrink tubing CA'd to the chassis, same with the RX wire. The rest is just shortening the wires as necessary.
I didn't use any servo crimps. All wires are soldered to the servo connector pins, then flattened with frustration.
...And yes I am anal enough to remove the Novak orange ring. It's 4 grams on the heavy side!!! ;-)
Changing to the BLS551 from the BLS451 saved 12 grams.
I do feel there's too much weight in the back when I drive, therefore I will be going bigger on the spur and pinion to move the motor forward next time out.
All carbon fiber is sanded via the CRC method, with the added step of using electric blue faskolor paint before CA'ing. Didn't color the top deck, I thought it was too much.
My soldering to the motor can be cleaner, but I need a bigger chisel tip (which I have) but the gun doesn't fit it....ugh.
The bumper DOES NOT RUB...until I crash. I have a touch more removal to do. It is the Parma hard cut-to-fit bumper. Its cut to fill all the area of the MazdaSpeed6 that is now mounted. The body does not fold under high speed, and takes less damage when tagged by the so-called-experts at my club. Orrin (Shopkeeper, 10th at the Reedy Race due to peeps hacking him) showed me that trick.
Losi ballcups are used, but wear fast. This helps with ballstud removal. TOP steel spool is used which is 6 grams heavier, but only $4 more, and lasts MUCH longer.
Trinity (IP) bullet connectors are used, as it is a solid piece, unlike most others which are 2 piece. Less resistance woot!
Old 09-03-2009, 01:30 AM   #624
sudhar93's Avatar
Send a message via MSN to sudhar93
What belt is that when i owned a tc5 i tought the belt was black
Tamiya-LRP - Team Powers - RIDE -Sorex -Protoform - Sweep -Futaba - GQ
-------------Car Needs Minor Tuning, Driver Needs Major Tuning -------------
sudhar93 is offline   Reply With Quote
Old 09-03-2009, 02:44 AM   #625
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
many use the Team Bomber belt ( which is white) for the yokomo BD, it is actuall a hair longer too which frees up the drive train a little .
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 09-03-2009, 08:28 AM   #626
Default belt
is that white belt still on the market ? what website or sites sell it?
isuzuguy is offline   Reply With Quote
Old 09-03-2009, 08:44 AM   #627
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
NICE job! The blue highlights on the chassis are very original!
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 09-03-2009, 09:08 AM   #628
syndr0me's Avatar
Trader Rating: 32 (100%+)
Man, that's beautiful, great work.
On the Novak, they make a black center ring if you decide the weight is worth it. Also, you can probably take a sharpie/paint pen to the orange under the solder tabs to make it blend in better. If someone questions it for tech, just pull the back off and you can plainly see it was the orange ring.
syndr0me is offline   Reply With Quote
Old 09-03-2009, 09:12 AM   #629
Jackster's Avatar
Trader Rating: 19 (100%+)
Nice work, Gordie. That is fantastic.
Jackster is offline   Reply With Quote
Old 09-03-2009, 09:36 AM   #630
sweet!
(",) is offline   Reply With Quote
Tamiya TA05 Touring Sedan kentech Electric On-Road 11396 03-16-2017 06:06 AM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
SMC 4000/25C/3.7V single cell Hardcase pack. Danny/SMC Electric On-Road 1022 03-10-2010 07:56 AM
