Old 03-07-2009, 09:09 PM   #301
Mark506's Avatar
Trader Rating: 41 (100%+)
Originally Posted by IIGQ4U View Post
Hey, to be honest with you, I don't remember the manufacturer of the tray. Perhaps somebody else could chime in. As far as the placement of the battery, it can be brought a little closer to center.
Below is how the LiPo would normally appear
Im pretty sure Specialized RC makes it, which is a brand of Corally. Here is link of it:
http://www.corallyusa.com/istar.asp?a=6&id=SRC79867!SRC
Mark Ament
l MOMO USA l OZ Racing l Willwood Brakes | Dunlop Tires |
The Raceway at Beaver: Forever In Blue Jeans
Mark506 is offline   Reply With Quote
Old 03-07-2009, 09:21 PM   #302
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Originally Posted by or8ital View Post
Just a word of caution. My MTR PT didn't like being stood upright. It was very picky about it's location.
Good thing I don't have a MTR transponder.
I haven't heard of any other issues with the transponder being on its side so since it's already installed, I will see how things go and make adjustments from there if necessary.
IIGQ4U is offline   Reply With Quote
Old 03-07-2009, 09:23 PM   #303
IIGQ4U's Avatar
Yep, it's Specialized. To keep the LiPo from moving inside of the tray, I use Dubro adhesive backed foam strips.
Old 03-07-2009, 10:37 PM   #304
edhchoe's Avatar
Questions??
My question is how to make the servo wire and the switch wire short.
And are these any good?
If they are good, any tips on soldering wire on them? TIA.
edhchoe is offline   Reply With Quote
Old 03-07-2009, 10:45 PM   #305
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Well, you have a couple of options.
First, you can cut the wire and then crimp the receiver male plugs onto each indivisual wire, or, you can dissasemble the certain electronic unit and directly solder the leads to the PC board after they are cut, of course.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 03-07-2009, 10:56 PM   #306
edhchoe's Avatar
First, you can cut the wire and then crimp the receiver male plugs onto each indivisual wire, ...
Do you use the existing plug and pull the tips out somehow or do you buy new ones?
Old 03-07-2009, 11:00 PM   #307
You can do either,
its easiest to take the existing plug and gently "pry" at the plastic area below the shown metal "tip", you can do so easily with an x-acto or a small flathead screw driver. This plastic tab keeps the tip from sliding out of the plug, when it is lifted, a gentle pull on the indivisual wire will realese the metal pin from the plastic.
Its kinda hard to explain, but in this pic you can clearly see the "tabs" and below them the gold plated "pins"
Old 03-07-2009, 11:04 PM   #308
Here are pics of my TC5 that I just finished.
The servo and transponder wires have been modified. The esc wire has not been modified. The sensor cable is 70mm in length.
WOW. Companies should hire you to put electronics on their cars for photo shoots! that is truly superb!!
Old 03-07-2009, 11:04 PM   #309
edhchoe's Avatar
You can do either,
And then you pry the metal thing to get the wires out...
Thanks!
Old 03-07-2009, 11:05 PM   #310
Thanks!
Yes sir!
No problemo.
Old 03-07-2009, 11:10 PM   #311
IIGQ4U's Avatar
I did mine by cutting the wire near the servo to shorten. I then reattached and placed heat shrink around the individual wires and the used heat shrink around all of the wires. I tried to shorten using additional hardware but I couldn't ever install it properly.
Old 03-08-2009, 07:22 AM   #312
Trader Rating: 38 (100%+)
Sorry about the typo, MRT. It could be the bridge location relative to where it's installed. I just know it was an issue for me so if you miss the occassional lap something to think about. Just trying to help.
or8ital is offline   Reply With Quote
Old 03-11-2009, 09:54 PM   #313
Johnny Wishbone's Avatar
Default One of my TC
Here is one of my TC.
Old 03-11-2009, 10:39 PM   #314
edhchoe's Avatar
When you unplug Deans plugs, do you hold the plugs or the wires?
Old 03-12-2009, 01:11 AM   #315
Just needs two wires of the battery and thats all
prinsdrift is offline   Reply With Quote
Tamiya TA05 Touring Sedan kentech Electric On-Road 11403 06-21-2017 03:10 AM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
SMC 4000/25C/3.7V single cell Hardcase pack. Danny/SMC Electric On-Road 1022 03-10-2010 07:56 AM
