Old 04-26-2013, 11:42 AM   #2341
John Doucakis's Avatar
Originally Posted by IIGQ4U View Post
How long do you think it takes a photographer to go to the studio and set up for a shot like this and then post process? Probably a bit longer than five minutes don't you think?
If you were following the thread a couple of pages back, you would see that I had already corrected the issue on the car.
I m with you on this. Nice clear photos take a lot of effort and time and it is not as simple as it looks.
Nice work.
John
JD & RACING BLOG
John Doucakis is offline   Reply With Quote
Old 04-27-2013, 08:24 AM   #2342
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Thanks John. I'm glad you get it.
Your wiring jobs are excellent as well.
IIGQ4U is offline   Reply With Quote
Old 04-27-2013, 09:08 AM   #2343
Send a message via ICQ to JiuHaWong
Originally Posted by mxgregg View Post
Whats the best or easiest way to shorten servo and esc wires to cleanup my wiring?
Last edited by JiuHaWong; 04-01-2014 at 08:24 AM. Reason: Tired of people who don't do their own research, and instead rely on others to spoon feed them information
JiuHaWong is offline   Reply With Quote
Old 04-28-2013, 07:46 AM   #2344
Baja-Boy's Avatar
My crc gen-xl.... Whatcha think?
Baja-Boy is offline   Reply With Quote
Old 04-28-2013, 08:23 AM   #2345
Bishop's Avatar
Sweet, the VTX1 looks good, as does the whole car, I just finished tidying up my Serpent 12th, I'll have to post a pic tomorrow of it.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 04-28-2013, 09:45 AM   #2346
Baja-Boy's Avatar
Honestly the vtx1 is so much smaller than my havoc 1s that I had, with it wired up all tidy like this the car is much more balanced and more weight is right in the center. where I race we don't have ozite so a center battery car would be no help for me. However being able to put all the electronics in super tight really helps the car handle. plus body can be extra low now too, especially since the motor wires do not have to cross at all and the esc is SO much lower. my sensor wire is also super out of the way.
Old 04-28-2013, 09:19 PM   #2347
Bishop's Avatar
Ok, mine is somewhat finished, shortening leads is something I always seem to put off lately, in part because the replacements pins/plugs I have seem poor quality, some older ones I had were really good, all the stuff I seem to have left have crap pins and overly small wire holes in the plugs, wish I could remember where I got the original ones from.
I should just get a crimper, I solder the wire into the new pins currently, it works ok, but it's just time consuming.
After working on the little Serpent, I can say that I really want the On-Point chassis, it looks nice...
Inspire us.  Show me your BEST, CLEANEST electronics installation pics.-tidy01.jpg   Inspire us.  Show me your BEST, CLEANEST electronics installation pics.-tidy02.jpg
QRCCRA
www.qrccra.org.au
Old 04-28-2013, 11:17 PM   #2348
Baja-Boy's Avatar
Very clean look there, nice job. been a fan of serpent lately. Considering a TC from them but I keep talking myself out of it. The esc looks pretty small, what are it's specs? also how do you like the thunder power motor? (I decided on d3.5 because there is more trinity locally) also how do you like the savox?
Old 04-29-2013, 12:36 AM   #2349
Bishop's Avatar
The build quality of the Serpent seems a little rough, both I and a friend found the lower front arm holes in the chassis drilled a bit off, meaning you have to file them out, or the front end tweaks a fair bit, also getting the kingpins smooth in the front pivot balls was difficult, I ran into other issues as well, including having to use Team Associated balls on the pod links to get them all good.
Now it's sorted it's fine, but it took more effort than you'd expect, though it's my first 12th scale, but I'd still really like the On-Point chassis to put on the car, it's looks a nicer design that works with all the Serpent parts.
It's a Core-RC Pace-45R ESC, only 45amp which should be ok cause for now it's just running a 10.5T motor, it's was cheap enough, and has good throttle feel, but it's a little on the tall side, right now the body rests/sits on the heatsink fins.
The other weird thing I found when fitting it, just about every ESC I know of has the motor phases running ABC, but the Core-RC runs CBA, which is really weird, and messes with having the wires neater running to the motor.
And I have been using thunder power motors for getting close to a year, and I like them, everything is rebuildable/replaceable, I have a spare with like 17.5 and 13.5 stator for, if I need to change winds I just grab a new $30 stator for it.
Savox servo seems fine so far, I ended up with a 1257 mini, which actually seems to be super fast, so suits the 12th, only minor pain was the mounts are really different to other servos, I had to drill new holes on the chassis to get it to fit the way I wanted.
QRCCRA
www.qrccra.org.au
Old 04-29-2013, 05:43 AM   #2350
Highly modded esc wiring(programming button moved to the esc case and soldered to the pcb,removed on/off switch...), shortest possible wires I could get a way with a link car.
Inspire us.  Show me your BEST, CLEANEST electronics installation pics.-p1050149-medium-.jpg   Inspire us.  Show me your BEST, CLEANEST electronics installation pics.-p1050147-medium-.jpg
fastvee is offline   Reply With Quote
Old 05-02-2013, 05:35 PM   #2351
mxgregg's Avatar
Trader Rating: 32 (100%+)
I bought a Futaba crimpping tool and shortened all my wires on my TCXX
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
Old 05-02-2013, 07:00 PM   #2352
Extra points for yellow wheels!
-Mike
Old 05-03-2013, 01:11 AM   #2353
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
My BD7 not too long ago. I'm working on the fan, sensor wire, and servo wire right now.
Racing4Evo is offline   Reply With Quote
Old 05-13-2013, 06:05 PM   #2354
IIGQ4U's Avatar
Per the suggestion of Blacked Out Revo, I have blacked out some parts on my VBC Wildfire as well as added a fan and added a few other upgrades.
What do you guys think of the car with the dyed parts?
Blacked Out by IIGQ4U, on Flickr
VBC Wildfire Black by IIGQ4U, on Flickr
Old 05-13-2013, 06:18 PM   #2355
Potoczak's Avatar
Trader Rating: 109 (100%+)
I must say it looks awesome!!!
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Tamiya TA05 Touring Sedan kentech Electric On-Road 11398 04-23-2017 07:20 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
SMC 4000/25C/3.7V single cell Hardcase pack. Danny/SMC Electric On-Road 1022 03-10-2010 07:56 AM
