Old 02-18-2013, 05:50 AM   #2266
naaarf's Avatar
Default 1st try
Hello everybody,
as im completely new to rc this is my first post
Thought id share some pics of my first attempt in electronics installation.
I had a little help from a buddy to be honest.
Its still not perfect as some others here, but for now im ok with it
So this is my Xray T4.
Suggestions and comments are welcome
Anybody knows where i can get orange wires that match the anodized orange of the car in Europe?
Regards from Germany
Inspire us.  Show me your BEST, CLEANEST electronics installation pics.-t4_1.jpg   Inspire us.  Show me your BEST, CLEANEST electronics installation pics.-t4_2.jpg   Inspire us.  Show me your BEST, CLEANEST electronics installation pics.-t4_3.jpg
Xray T4 / LRP Sxx Mod+Stock / X12 17.5t / Sanwa MX-V
naaarf is offline   Reply With Quote
Old 02-19-2013, 09:15 AM   #2267
mxgregg's Avatar
Trader Rating: 32 (100%+)
My new TCXX.
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
Old 02-22-2013, 07:11 PM   #2268
Radi0Flyer's Avatar
Wow, I thought my wiring was decent...until I found this thread.
Maybe I could get some advice on my CRC Xti?
I want to shorten the servo and ESC leads to the receiver, maybe twist them? What about the sensor wire and motor leads, sleeve them? I'm using 16AWG to the motor but it looks big compared to some of the stuff some of you are using. Can I go smaller or is that just for pics? The motor is a 13.5 Reedy.
Sean
I'll drive it til the wheels fall off and burn
Radi0Flyer is offline   Reply With Quote
Old 02-22-2013, 08:33 PM   #2269
Trader Rating: 40 (100%+)
#1 smaller wire. black blends in better. 18 guage is great for stock classes for mod run 14
i take my servo wire out of the connector (carefully) and shorten the wire there by soldering the shortened wire to the end. and then re-installing it into the connector.
Try to run the motor wires beside your battery down low and loop them up to the top of the rear pod just under the damper tubes. And for the cap pack just switch over to the single (like the tekin).
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 02-22-2013, 09:06 PM   #2270
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
those wires look a little taught for my liking. i like to loop them around over the pod to eliminate the chance of them binding. extra wire also helps get closer to minimum weight =)
My stuff
| Sanwa M12 - Team Associated - Reedy - ProAMPS RC - Novarossi |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/
valk is offline   Reply With Quote
Old 02-22-2013, 09:44 PM   #2271
DesertRat's Avatar
Hell, my wiring jobs are consistently very clean for where I race but some of these make me look like a complete hack because I don't shorten the leads or go all single color... Maybe my next toy will be a fine electronics soldering iron so I can shorten/replace leads.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 02-23-2013, 05:59 AM   #2272
abailey21's Avatar
Trader Rating: 36 (100%+)
that should have been the first thing you buy when deciding to race electric?
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 02-23-2013, 06:06 AM   #2273
abailey21's Avatar
Sean
one, use smaller wire, 18 gauge, and a little more than you have, looks almost like your binding the rear pod the wires are so tight. get some here... TQ Wire
two, GET THIS and then you'll need a bag of these, and now you have the tools required to shorten you servo leads WITHOUT soldering servo line on your servo or esc which requires a very gentle hand
K.C.C.O.
Old 02-23-2013, 07:05 AM   #2274
DesertRat's Avatar
I solder big connections with a 150 watt soldering gun, I cant use that to hit a 1mm contact with a 24 gauge wire sticking out of it, nor could you use one of the big chizzle-tip irons used by other racers. It needs to come to a super fine point, and not get too hot so you don't burn your circuit board.
On this point, it is depressing to see somebody trying to solder 12 gauge wire with a small tip iron, I have re-done quite a few soldering jobs so they're right.
Old 02-23-2013, 10:29 AM   #2275
StevenOlsen's Avatar
Originally Posted by naaarf View Post
Hello everybody,
Demonpowerproducts.co.uk
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 02-23-2013, 02:03 PM   #2276
naaarf's Avatar
Not sure if i should really try coz the esc will still stay blue ...
Maybe i can find a way to change it to black and still keep the label print on the top visible
Well see
Old 02-23-2013, 03:28 PM   #2277
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
Originally Posted by mxgregg View Post
My new TCXX.
Black Sharpie and shrink tubing are your friend.
Also, I would tape the switch on top of the receiver or servo and lose the strap.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 02-23-2013, 03:32 PM   #2278
Riketsu's Avatar
Originally Posted by narcotiks View Post
My 417 V5
Hope you guys like it
I cannot begin to describe how awesome this car looks. Temps me to switch brands.
You can probably re-route the sensor cable to pass in front of the fan and back around into the esc.
Old 02-24-2013, 03:26 AM   #2279
John Doucakis's Avatar
My latest install with the new Team Orion VST2 motor.
More details in my blog
JD Racing Blog
John Doucakis is offline   Reply With Quote
Old 02-24-2013, 06:41 AM   #2280
Trader Rating: 57 (100%+)
I check your blog every day. I hope more mfg's follow Orion with the 2 directional sensor wire ports.
PROMODVETTE is offline   Reply With Quote
Tamiya TA05 Touring Sedan kentech Electric On-Road 11398 04-23-2017 07:20 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
SMC 4000/25C/3.7V single cell Hardcase pack. Danny/SMC Electric On-Road 1022 03-10-2010 07:56 AM
