Old 06-01-2012, 10:05 AM   #1936
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by DesertRat View Post
Good idea on the antenna wire, but keep in mind that what you have built there is an air-core inductor, a few tents of a micro-henry by the look of it, and even though its not doing anything bad for you in the way you have it, it IS possible to bundle the thing up in such a way that at a certain signal strength (a certain distance from the transmitter, may be two inches or two miles, but most likely never) and a certain frequency, it will blind out your signal and you will have a badly working R/C airplane instead of a car. I'm a little bit of a stickler for this stuff, and its almost certainly no problem, but for the asthetics its not a risk I would take. I just string mine up through my front suspension and body post holes.
Hey, they made me learn this shit in school, I might as well use it for this as I certainly don't use it for my job.
RC Tech needs more posts like this. Very good insight, thank you.
syndr0me is offline   Reply With Quote
Old 06-01-2012, 11:40 AM   #1937
erchn's Avatar
I use the exact same antenna "bundling" technique. Is there a way of cancelling out this effect? Such as, if I run the end of the antenna through the wrapped antenna would that cancel it out?
erchn is offline   Reply With Quote
Old 06-01-2012, 12:20 PM   #1938
DesertRat's Avatar
Like I said, its not a big deal unless you hit the wrong combo right on the head of the nail, so don't worry, its biggest drawback would be limiting your range, but isn't a problem if you just run indoors and never have the car more than a hundred yards from you. Definitely not a suggested setup for airplanes.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 06-01-2012, 05:04 PM   #1939
Trader Rating: 38 (100%+)
Here is the best I could do. Didn't come out as well as I had hoped . I ended up having to add 45g of weight to the outside edge to get the car to balance and the car is still significantly lighter than my TC6.1 was (where I only had to add 30g).
Wires in the servo we re-routed out the other side and switched to black wire. Same for the Tekin RS. Replaced the PT wire with black. Painted the Seis fan wires black.
Also removed the nub since someone gave me a hard time earlier . Now to finish setting it up and paint a body so I can race tomorrow.
or8ital is offline   Reply With Quote
Old 06-01-2012, 05:09 PM   #1940
MikeXray's Avatar
Trader Rating: 72 (100%+)
Run your power wires over the top deck, and push the battery under the top deck, this will let you use a lot less weight to balance, then just add what you need to make min down the center. Put the sies fan in front of the motor below the tekin, this will redistribute its weight a bit to help.
I only have 10g on the left side for balance, but the LRP is a little heavier than a tekin.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 06-01-2012, 05:11 PM   #1941
Do I just rely on tape to hold in place or how do I keep it from running into the belt? Maybe I missed something.
Old 06-01-2012, 07:16 PM   #1942
MikeXray's Avatar
If you use an xray center weight, that works, I have screws in the center holes, and dremeled plastic nuts to act as stoppers. You could shoo goo a small piece of carbon or plastic as well.
Old 06-02-2012, 08:52 AM   #1943
MikeXray's Avatar
Just redid my car:
Old 06-02-2012, 08:58 AM   #1944
syndr0me's Avatar
Do you prefer that look over moving your electronics in closer to the middle and placing those weights flat on the chassis? You could cover them with a CF sticker. Or what about stacking them up behind your servo on their side? It would be kind of like having a normal length servo, but you've got the room.
I've never seen a competitive car with weight hanging off the side like that. Never.
Old 06-02-2012, 03:20 PM   #1945
I planned to lay them flat between the motor and esc but couldn't get it to balance there without making the car overweight. Also you've seen plenty of competitive cars with weight hanging off the side. Just look at the battery side.
Old 06-03-2012, 12:11 AM   #1946
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
E4RS. this is not nearly as clean as i would have liked, but it was an experiment really. got TONS of sleeving and heatshrink to try again later.
valk is offline   Reply With Quote
Old 06-03-2012, 09:16 PM   #1947
DesertRat's Avatar
Nowhere near as ugly as my car, thats for sure.
Old 06-04-2012, 10:40 AM   #1948
syndr0me's Avatar
Surprised none of you are sporting this yet:
http://driftmission.com/active-hobby...eceiver-shell/
Old 06-04-2012, 11:59 AM   #1949
valk's Avatar
Esc shield would make more sense to me. Much more money to get smashed. Doesnt seem like a worthwhile purchuse for onroad cars though.
Old 06-04-2012, 12:37 PM   #1950
burgboyz's Avatar
Trader Rating: 70 (100%+)
Hey Syn,
Send me one and I will switch to Futaba just to try it out! Blue please.
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Tamiya TA05 Touring Sedan kentech Electric On-Road 11396 03-16-2017 06:06 AM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
SMC 4000/25C/3.7V single cell Hardcase pack. Danny/SMC Electric On-Road 1022 03-10-2010 07:56 AM
