Old 05-25-2012, 01:09 PM   #1921
BL converted Kyosho Inferno GT
dark_luna is offline   Reply With Quote
Old 05-31-2012, 09:10 PM   #1922
Trader Rating: 38 (100%+)
Transponder position:
1) on the servo
2) on the chassis
Thoughts?
or8ital is offline   Reply With Quote
Old 05-31-2012, 09:28 PM   #1923
CypressMidWest's Avatar
Originally Posted by monkeyracing View Post
If 12th scale was able to run rubber, I'd buy one.
If rubber tire TC's could be made to handle well, then I'd buy one of those.
Team CRC, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 05-31-2012, 09:35 PM   #1924
haywood's Avatar
Trader Rating: 48 (100%+)
Default Mine
1) on the servo
2) on the chassis
Thoughts?
http://www.rctech.net/forum/attachme...s-dsc02715.jpg
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 05-31-2012, 11:14 PM   #1925
racer x 1's Avatar
Trader Rating: 27 (100%+)
Originally Posted by haywood View Post
wait was everything mounted that far out to help balance the car with less weight?
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 05-31-2012, 11:51 PM   #1926
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
Very trick manual brake setup on the Inferno, love it.
Dan is offline   Reply With Quote
Old 06-01-2012, 01:26 AM   #1927
Robert_K's Avatar
1) on the servo
2) on the chassis
Thoughts?
Place the elec's far more inboard? Then place the receiver against the Servo, place the RC against the receiver (more inboard). Then there is a gap between the servo, receiver and Tekin, towards the end of the bottomplate. That's a nice spot for the PT if you ask me.
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 06-01-2012, 06:41 AM   #1928
Regards Robert
I agree with that from a looks standpoint. Unfortunately I am anticipating having to move all my electronics out to the far edge to get proper balance. We will see. Just finished building it last night and still need to set it up.
Old 06-01-2012, 07:25 AM   #1929
M-Technic's Avatar
Trader Rating: 15 (100%+)
I have my electronics quite outboard on my T3 12 also, the car balances out much better that way.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 06-01-2012, 09:03 AM   #1930
haywood's Avatar
Default T3 2012
I see you installed the new servo mount but did not remove the nub sticking out on the chassis. I thought that was the bonus of that mount so you could dermel that off so it won't catch the carpet on sweepers?
Old 06-01-2012, 09:38 AM   #1931
I just havent removed it yet. Trying to prioritize the things I need to get done to race it this weekend and that might not make the cut.
Old 06-01-2012, 09:50 AM   #1932
syndr0me's Avatar
Trader Rating: 32 (100%+)
If you end up moving your electronics toward the center, you can make the inside edge of your receiver line up with the inside edge of the servo. That can give you a nice flat spot to mount your transponder out of sight. It should be able to clear the belt.
Receiver and transponder are so light, I don't really worry about using them for ballast. I run an ESC with a little meat on it (v3), and between it and the motor, there's plenty of weight on the outside edge. You can always move your electronics toward the inside to keep them safer and then put some weight next to them, too.
syndr0me is offline   Reply With Quote
Old 06-01-2012, 09:52 AM   #1933
syndr0me's Avatar
Also, try coiling your receiver wire around a screwdriver and then put shrink over it. You can stick it to the top of your receiver and be done with antenna tubes forever. It works fine. Here's an example from my 1/12
Old 06-01-2012, 10:33 AM   #1934
For whatever reason I've always try to put my heavier weight toward the center and the lighter weight items toward the outside. For some reason this makes sense to me.
Old 06-01-2012, 10:46 AM   #1935
DesertRat's Avatar
Good idea on the antenna wire, but keep in mind that what you have built there is an air-core inductor, a few tents of a micro-henry by the look of it, and even though its not doing anything bad for you in the way you have it, it IS possible to bundle the thing up in such a way that at a certain signal strength (a certain distance from the transmitter, may be two inches or two miles, but most likely never) and a certain frequency, it will blind out your signal and you will have a badly working R/C airplane instead of a car. I'm a little bit of a stickler for this stuff, and its almost certainly no problem, but for the asthetics its not a risk I would take. I just string mine up through my front suspension and body post holes.
Hey, they made me learn this shit in school, I might as well use it for this as I certainly don't use it for my job.
I race toy cars for fun. If I need to explain, you'll never understand.
If everything is under control... go faster.
WTB: Carpet racing in Arizona.
It is obvious and intuitive to the most casual of observers that RC racing is better than golf.
DesertRat is offline   Reply With Quote
Tamiya TA05 Touring Sedan kentech Electric On-Road 11395 01-14-2017 12:51 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
SMC 4000/25C/3.7V single cell Hardcase pack. Danny/SMC Electric On-Road 1022 03-10-2010 08:56 AM
SEO by vBSEO 3.5.0
