Old 03-07-2012, 08:40 AM   #1801
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by axle182 View Post
Dont suppose you have a pic? Did you use solder or a small amount of wire to short the switch? Love the idea for TC, but not for 12th, its too hard to plug in the batt with the body on. But no switch would definately help the look of the 12th
Yep, small piece of wire. There's room in there, so you don't have to make it so short it's hard to do.
I've kinda reached the point where a switch on a dongle is a pet peeve of mine. The new Hobbywing V3 with the integrated switch got it right.
syndr0me is offline   Reply With Quote
Old 03-07-2012, 09:07 AM   #1802
Originally Posted by Slo_E4 View Post
Thanks, actually it wasn't that bad. Just take your time, steady hands, and use your common sense the whole way through. Make sure you pay attention to the way the lead goes.
Little things that helped: when you shorten the TQ wire, dab a little flux on the end, and then a dab of solder. Keeps the tiny wires together.
Use flux, and do one at a time on the board, holding each one down with a small flat head. Also I had a vice to hold the rs itself.
I've never understood people who shorten the wires by crimping, soldering to plug pins or just by cutting a bit off and soldering back together. I'ts so much hassle compared to just cutting the lead and resoldering inside the servo. Those solder points are not so small, if you got a steady hand you don't even need too small of an iron. Though there are some exceptions - anybody who has tried to shorten the wire on higher end sanwa servos knows what i am talking about.
Marten is offline   Reply With Quote
Old 03-07-2012, 09:39 AM   #1803
Infinite 12th's Avatar
I like just buying those gold connectors that fit inside the plug then snip the wires at length desired then solder gold connectors to wire then pop in plug again
Infinite 12th is offline   Reply With Quote
Old 03-07-2012, 12:01 PM   #1804
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
i might have to crack open my savox servos in the future to shorten them.
ive done the tekin esc rewire which really wasnt any worse than soldering to any other small electronic bits. might save myself some future grief.
valk is offline   Reply With Quote
Old 03-07-2012, 12:44 PM   #1805
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Originally Posted by ralph m View Post
I'm always impressed by the neat wiring on this thread - some amazing examples here!
Also, many thanks for your support. If you guys have a suggestion or a need for something that's not currently available, send me a PM or email.
Props to TQ, ordered today, Paid today, they shipped today and sent a refund for lower than expected shipping charges. Now thats service! Thanks Ralph. Ill be sure to put up pics when ive got it all done. I have a sweet R5.1 Lipo car ive been wanting to pimp
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 03-08-2012, 08:45 AM   #1806
Suteki's Avatar
If you're like me, it's because you're not totally proficient or confident in doing it straight to the board itself.
I have badly pinched the wires leading from the esc to the receiver. I opended up my RX8 esc and looked at it and saw how small the connections were and thought while I could probably do it, I didn't want to go experimenting with it as I just don't have the funds right now to replace the RX8 in the event I stuff it.
My biggest concern would be getting too much solder in there and leading to a situation where solder was passing the current between two or more of the connections.
So for my, cutting down the wire itself, and grafting on some new wire is a lot less of a risk than getting into the ESC and attempting a clean install from the ESC board itself.
If grafting some new wire onto the end before where I pinched the original cable doesn't have any adverse effects and is easier for me to do with confidence, I think I would rather take that route.....
Losi SCTE - Tekin RX8 / Pro4 4600 / Futaba ***** Mugen MBX6 Eco - Tekin RX8 / T8 1900 / Savox ***** Mugen MBX6TR - Eco / Tekin / Futaba ***** Emaxx - FLM / UE Supermaxx / Tekno hop ups ***** Axial SCX10 Honcho RTR (stock) ***** Losi 5ive T - Futaba / VRC / Rooster Tail 30.5cc / SNR
Suteki is offline   Reply With Quote
Old 03-08-2012, 10:14 PM   #1807
Swampracer's Avatar
Trader Rating: 68 (99%+)
Default SC lovin
Got to show a little love for SC trucks!!! Not to many on this thread
Cheers
Inspire us.  Show me your BEST, CLEANEST electronics installation pics.-img_0307.jpg   Inspire us.  Show me your BEST, CLEANEST electronics installation pics.-img_0308.jpg   Inspire us.  Show me your BEST, CLEANEST electronics installation pics.-img_0309.jpg   Inspire us.  Show me your BEST, CLEANEST electronics installation pics.-img_0310.jpg
Swampracer is offline   Reply With Quote
Old 03-08-2012, 11:38 PM   #1808
TryHard's Avatar
Originally Posted by TryHard View Post
Cheers for that, I'm deffiently going to give that a shot with the Savox when my TQ order turns up.
Anyway, latest install at the moment... waiting on a few more bits to arrive, but I am digging the red motor wire, matches the batt good (and only reason I used it was had run out of black!!)
Fan wire needs tidying up, but difficult to route... any ideas? Otherwise, ESC wire needs lengthening to allow better routing, but given it's a HW V3, once it's in the Rx, never needs to come out again as all programming is done via the front port! And the inbuilt switch (with back lit LED) is pimp!
Ed
Had to make a change to the wiring so I can switch between transverse and longitudinal motor layouts without re-wiring whilst testing this weekend... actually doesn't look as bad as I expected!
Inspire us.  Show me your BEST, CLEANEST electronics installation pics.-re-wire.jpg
Old 03-08-2012, 11:54 PM   #1809
TeamWTF's Avatar
Way to show off the new V3
T.O.P. Racing Australia www.topracing.net.au
TeamWTF is offline   Reply With Quote
Old 03-09-2012, 08:28 AM   #1810
Any comment on transverse and longitudinal motor layouts ? Which one is easier for setup, drive.....etc....
mos-leung is offline   Reply With Quote
Old 03-09-2012, 09:00 AM   #1811
TryHard's Avatar
With this car, the transverse gives more roll. The weight is further from the centreline, as the battery needs to be moved out 5mm to balance the car up. This does effect the setting of the car (needs to be a little stiffer), but I've got more testing to do before forming a firm conclusion!
Old 03-10-2012, 02:37 AM   #1812
Send a message via MSN to DORIYAA!
oh this is defiantly my section, will post up pictures of my VDF Wiring once the forum will let me post pictures hahahaha, great wiring jobs everyone, specially the awesomatix 700
DORIYAA! is offline   Reply With Quote
Old 03-10-2012, 06:43 AM   #1813
Default t3`2012 wire job
Hi guys.
After reading through this thread, and seeing all those clean installation pictures I thought I give it a try on my new T3`2012. What you think?
mritual.de/t312/t312_wire.jpg
I can't make it a link/image since I'm a new member sorry about that , copy/paste the url to view the picture. Again, sorry.
Patrick
Patrick_S is offline   Reply With Quote
Old 03-10-2012, 10:47 AM   #1814
monkeyracing's Avatar
Let's see if we can make Patrick's picture appear...yup! Pretty cool work. All you guys make me jealous. I'm the opposite of neat when it comes to wiring.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 03-10-2012, 11:45 AM   #1815
Thanks monkeyracing, for both the link and the kind words.
Tamiya TA05 Touring Sedan kentech Electric On-Road 11403 06-21-2017 03:10 AM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
SMC 4000/25C/3.7V single cell Hardcase pack. Danny/SMC Electric On-Road 1022 03-10-2010 07:56 AM
